Well after getting the car registered on Thursday Last week. The engine pretty much went bang on Saturday arvo, first thought it was a gearbox problem due to some serious clutch slipping. But we soon found out later it was quite serious and ended up being a number of things going wrong.
Anyway the engine is being re-built by Dan (3lite 32) and should be back tougher than ever (not giving to much away yet).
Anyways here's a few pics.
Just a couple from Thursday Night.
The Turbo.
And went she went bye bye
When you have an itch, you have an itch.
https://www.sau.com.au/forums/topic/111149-few-pics-of-the-engine/
we assumed a gearbox issue cause the knocking was faint to begin with and was near where the flywheel, but as the knocking got worse we did figure it was internal.
Yes it was a fresh re-build, but unfortunatly some parts which i assumed to be in there werent. The clutch was supposed to be a near new exedy heavy duty clutch, it wasnt. Just dont think it was re-built properly, cause either A. the mechanic wanted to save some $$$ or B. Couldnt careless.
Also cause it was a stock bottom end, also believe it wasnt built right to take the power the turbo would produce, even on such a low boost setting.
But i know now it will be built right and properly this time.
are u going back to see the guy u bought it off and have a word to him, i would, and take dan with u and get him to say what he saw when he pulled the motor apart. dodgy farker!!!!! id ask him where all the supposed parts were that he has supposibly put in the engine..... just put him on the spot and see what he says. and threaten him with legal action. (even if u are bull shitting)
Ok just a few things.....
I did not consent to the arse shots!....and I wasn't scratching.
It was very bad luck on Ben's part. I felt very bad for him because it had only been done a few weeks prior. I don't know that there was anything wrong with the bottom end to begin with but may have something to do with some spirited driving 600k's after the rebuild was done (very naughty), however a good engine should not have let go so easily. I am going to help Ben out as much as I possibly can with the rebuild as far as cost is concerned. Any help from others will be greatly appreciated so if you have anything which you may not need and you think it may help, just PM me or Ben to offer. Parts mainly.
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
