Hey guys, got a strange problem and got no idea what it is...
Got my alarm installed today, standard job, 3pt immobiliser, such and such. I drove it back home, then later on, turned the car on and went for a drive. First thing I noticed is the car felt for lack of a better word "sluggish" or heavy and when accelerating felt as if something was holding it back. After a couple of minutes the HICAS light activated and I thought "oh oh" As it's never come on before I have no idea what's up and thought some of you guys might have an idea or some reccomendations. Could the installer perhaps caused this to happen or is it just a coincidence?
Cheers
https://www.sau.com.au/forums/topic/111204-hicas-light-came-on/
Seems to be no change, anyone got a guide how to totally remove HICAS on an R33? I've been meaning to do something about removing it but always said I wouldn't until HICAS started playing up, looks like now is the time...
do a search in the tutorial/DIY section!
there is one in there that i used, very straight forward!
I've had an off and on problem with my Hicas since I got the car, it only happens when it's wet and the result was the same as your 1st post every time it rained or I washed it.
After much effort and attempts I tracked my fault to the connector on the power steering pump, I spray it with water dipersant and bingo no problem. I packed it in lanosol.
When you say the result was as my first post, are you referring to the "sluggishness" while accelerating? If so, where is the PS pump located so I can get to the little sucker to try to fix this problem
Guys, let me just say, easiest thing to do is get a lock bar and get rid of HICAS. Honestly, it's just a pain in the ass. I got sick of screwing around with my car trying to solve the problem so I ordered a lock bar and couldn't be happier!
Cost me $130 for the HICAS lock, did it myself, no special tools and VERY straight forward; even a guide here on SAU. Need to get a wheel alignment still however for the rear wheels but that's no biggie
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
