Is anyone going to Easternats this year?? im thinking about entering just to have a bit of fun on the track...
I am thinking about entering i had a few mates enter last year but they had a few troubles with the police soon as they see you drive out of the course, they see the sticker on the window and pull u over
https://www.sau.com.au/forums/topic/111221-easternats/#findComment-2050066
Al, im trying! Ill start coming to the track days as well, ive been getting the car setup and im nearly there!
I went last year to Easternats in a mates car and it wasnt to bad, your right about there being a lot of people but i really just want to get out there and abuse my car! since my new found power it is really hard to open it up on the street...
Im really just going for a laugh...
https://www.sau.com.au/forums/topic/111221-easternats/#findComment-2050936
if anyone goes keep an eye out for a purple VLT called "FATPSI" pretty wicked paint on that thing
I have seen this car booting around in my area i think... if its the one i am thinking about the driver is the biggest cock head ever.
https://www.sau.com.au/forums/topic/111221-easternats/#findComment-2054494
    • C34 Stagea RS4S Standard RB25DET Neo with ARP Headstuds and MLSR Gasket. Bosch 1000cc injectors Walbro 460 Standard neo inlet plenum w/rb25 s2 throttle body 6 Boost Low Mount Manifold Turbosmart Gen V 45mm wastegate (recirculated) Pulsar g30-770 (0.72 rear housing) 3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust Link G4X Ecu 380 hp on 98 octane, 478 HP on e85 (mainline hub dyno) Video of Earlier Run VID_300701109_043404_458.mp4 Final Dyno Sheet:
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
