Nsw Sau 1/4mile Pb's
silver gts-t
  • 3 weeks later...
  • 4 weeks later...
Stupid rain only got 3 runs :miner:
Best time:
13.239ET 2.20360ft 110.42Mph New PB! <room for improvement>
My best 60ft of the Night: 2.150 (clutch smelt good afterwards changed to 2nd too early and got the worst time of the time)
Best MPH 111.27(179.08km/h)
Sau Nsw 400m Registry
GTR
DiRTgarage: 10.36 @134mph r32 gtr (two.06l stacey 11.95 @121 mph)
SCOOP: 10.9 @ 127.40mph r32 gtr
T04GTR: 11.7 @ 116mph r32 gtr
wrxhoon: 11.8 @ 117mph r34 gtr
hot53x: 11.961 @ 112.77mph r32 gtr
Blitz: 12.0 @ 111mph r33 gtr
benm: 12.3sec @ 113mph r32 gtr
OFENSV: 12.123 @ 114.50mph r32 gtr
hanyou: 12.427 @ 111.95mph r32 gtr
JET-32R: 12.49 @ 106.66mph r32 gtr
Morgs: 12.53 @ 111 mph r32 gtr
GTRsean: 12.5 @ 116 MPH r32 gtr
GTR-27L: 12.7 @ 105mph r32 gtr
MIKE_R32_GTR: 12.851 @ 105mph r32 gtr
GTS-t/ GTT
MR331307: 10.8 @ 128mph r33 gtst
2RISMO: 11.662 @ 118.3mph r33 gtst
RNMENC: 11.75 @ 121mph r33 gtst
itboom: 11.8 @ 122mph r33gtst
ECR033: 11.945 @ 118.27mph r33 gtst
DoughBoy: 12.0 @ 123.7mph White car r33 gtst
DoughBoy: 12.1 @ 119mph Black car r33 gtst
88silhouette: 12.119 @ 111mph r31 sil
OFENSV: 12.175 @ 118.14mph r33 gtst
legend01: 12.220 @ 111mph r32 gtst
qwikky: 12.3 @ 109mph r33 gtst
moanie: 12.504 @ 112mph r33 gtst
abobob: 12.764 @ 106mph r34 gtt
mass iv: 12.91 @ 111mph r33 gtst
Guilt-Toy: 12.98 @ 108mph r33 gtst
yogi000: 13.1 @ 108mph r32 gts
ru3-29T: 13.3@ 105mph r33gtst
spx25t: 13.354 @ 103.23MPH r31 25t
race_snooze: 13.4 @ 111mph r33 gtst
cerci: 13.522 @ 103mph r33 gtst
GTshortie: [email protected] r33 gtst
kennedy: 13.615 @ 102.42mph r33gtst
silver gts-t: 13.62 @ 103mph r32 gtst
trust33: 13.6 @ 102mph r33 gtst
cuong nguyen: 13.761 at 106mph r32 gtst
RedDrifter: 13.7 @ 105 mph r32 gtst
cohen20: 13.7@?? r32gtst
JAS-25T: 13.8 @ 99mph r33 gtst
burnsie: 13.900@98mph r32gtst
SECUR1TY: 13.902 @ 101.36mph r33 gtst
Shonen: 13.934 @ 97.4MPH r34 gtt
JeeTeeEss25Tee: 14.01 @ 100.58mph r33 gtst
nath95: 14.04 @ 99mph r33 gtst
MaTBoY: 14.09s @ 99.55Mph r32 gtst
Siddr20: 100.15mph r33 gtst
mr moo: 14.191@ 96.76 r33 gtst
mike1987: 14.2 @ 97mph r32 gtst
jf R33: 14.258 @ 100.66mph r33gtst
tomm0: 14.3 @ 98mph r33 gtst
raz0r$harP: 14.516 @ 95.98mph r33 gtst
evil_weevil: 14.5 @ 94mph r33 gtst
d00dz: 14.53 @ 102.5mph r33 gtst
Tebie: 14.572 @ 94.24mph r32 gts4
sindows: 14.8 @ 96mph r33 gtst
the R32: 15.0 @ 101mph r32 gtst
Other
Boosted Zed: 10.709 @ 139.67mph 300ZX
Barry: 11.1 @ 123mph datto 1600
ido09s: 11.274 @ 121.79mph S14a 200SX
NBP: 11.8 121mph rx3 13bt
bmxwrx 12.4 @ 112mph MY00 WRX
TommO: 12.6 @ 108mph Evo VIII MR
DVS>VLT: 13.6 @ 104mph VLt
wokburner: 13.02 @ 109mph 300ZX TT
BLISTIC: 13.0 @ 109mph 180SX
PORTS: 13.433 @ 105.39mph z32 300zx
Felix st: 14.7 @ 94mph 98 Honda Integra VTIR
Will be updated. :laugh:
Edited by johno_shaun
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
