beat my PB tonight with a 10.907 @ 129mph. did it on my last run of the night which was good so i still got 3 runs in before that
Yeah, I was watching it from the barrier next to the start line (mate was racing his bike). Very impressive mate :) Certainly sounds great... nice bangs on rev limiter hehe
Edited by TommO
cheers :) I'll be back next friday the 1st feb to have another go. dont want to do another 10 straight up though, want to get my moneys worth. I still havent bought a super street licence yet and ive done under 12's the last 4 times ive raced lol
Well done on the 10.9 :) Car looked good and goes even better. Garrett 2860-5's?
There was also a white R32 GTR with QLD plates that ran a 10.4@134 (I was told it ran 10.1 earlier).
thanx mate, nah im running hks 2530's. yeah i saw that white one do the 10.4 heard it's a TRP car Did that car have a cage?
Edited by OFENSV
pb of 13.67 @ 100mph last feb fastest run of 104mph, need more practice :P
sorry forgot to say was in a r33 gtst, cooler, turbo back exhaust, pod, apexi power fc makin 190rwkw on 12psi, pingin its head off, needing a retune, have been back since ran a 13.71 @104mph detuned to 180rwkw, waiting for more funds to upgrade turbo and fuel system, i want 300 rwkw with a 35r 700/800cc injectors, big fuel pump surge tank etc, give me 12 moths or so hahaha, i cant wait i wish i had thew coin now!!!! hopin for 12s, 11s would be beter!!!!!! hahaha ill update my progress :ermm:
  • 3 weeks later...
11.7 @ 122mph, 1.8 60ft.
I've gained 5mph, but only 0.1 on the ET.... traction has become a real problem lol. I managed to nail a 1.6 in one run but unfortunately shifted into 2nd a bit too early. Ended up witrh a 11.7 @ 117mph that run... dammit, that would have been my 11.5 :)
Edited by TommO
Congrats Mate!! Awsome stuff!!!! :) Make them update the thread!!, you deserve the recognition. You are driving it spot on ;) And am enjoying your progress.
Thanks dude :P, Yeah im not sure if he still updates this thread, think its been awhile.
Thanks dude :) , Yeah im not sure if he still updates this thread, think its been awhile.
When are you running next? Ill have to get the 34 down there and see if i can run i 15sec QTR haha... I'd be lucky to run that the way the clutch is at the moment :)
hey mat, you have a new name thing.
I was ment to be going to a private day with V8 owners club but had to pull out due to lack of money. not working doesnt help haha
Yeah, i figured 32GeeTeeR was a little innapropriate considering i drive a 34GTT :laughing-smiley-014:
Get a job ya bum... So i can watch you run the 1/4... Once i do clutch and injectors ill have a crack...
Anybody know what a mild 34 is supposed to run?
  • 4 weeks later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
