Just came back from WSID tonight it was COLD! and very few cars i got there around 7, and still got 7 RUNS!!!.. finished around 9:45 as well.
Anyways
r33 gts25t -
r33/s14 Stock RIms with T1R's 205/55/r16
2.082-60ft ET [email protected]
the whole night i was doing 2.2 or better 60ft's and consistent 13.6-13.7 passes.
what a difference Lighter STOCK rims make!
Nah i was in the STOCK looking WHITE R33 Gts25t Series 2 with STOCK r33/s14 rims and a HKS sticker over the front widescreen.
i can't believe after so many times of heading down to WSID trying to break into the 13's the only thing i had to do was run my stockies to get into the 13's with ease!
2.082 60ft with 205/55/r16 Toyo T1R's @ 32psi
compared to best of
2.382 60ft with 255/40r17 Dunlop Formula RSV's. @20-30psi
what kind of mods do u have? my best is 13.8 @ just over 100mph. interesting....i did this time on 19" with 10" wide rears.....I have some 17" with 9"rears...should i expected much better? how much lighter are the stockies?
Brendan remind me 1 wednesday nite to bring down my nitto's on 300zx rims for u to try out, they are practically bald anyway but still going to be better than 19's.
Edited by benm
I was there last night.
Got 14.10 at 100.15 MPH
Just couldnt get my launch right. Was hopin to hit into the 13s..
Only got full exhaust.. But still, would have loved to hit 13.99 hahah
Btw i was the one with mismatched rims!!
Work rims on the front, and Buddy club Rims on the rear!!
Btw how do you obtain pics from those guys?? Do we have to ring up wsid and order them or what? cheers
Oh you think my time is alright or i could have done better??
Edited by siddr20
so how many other 33s did you pwn burnsie? perhaps you should be offering driving lessons to the others.
hahaha there really wasnt that many out. but nismo god (brendan) in his 33 was posting some quick times with a stocker in the 13's i think his last run with bald slick was a 13.4
Had my first time out on the track at wsid on wednesday. I managed a 14.258 @ 100.66mph and 60ft of 2.349.
I have stock r33 s2 except for 3" turbo back exhaust and cooler. I think my 18's and street tyres held me back alot.
Anyways
r33 gts25t -
:) congrats dude!!!! :)
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
