  • 3 weeks later...
  • 4 weeks later...
Stupid rain only got 3 runs :miner:
Best time:
13.239ET 2.20360ft 110.42Mph New PB! <room for improvement>
My best 60ft of the Night: 2.150 (clutch smelt good afterwards changed to 2nd too early and got the worst time of the time)
Best MPH 111.27(179.08km/h)
Sau Nsw 400m Registry
GTR
DiRTgarage: 10.36 @134mph r32 gtr (two.06l stacey 11.95 @121 mph)
SCOOP: 10.9 @ 127.40mph r32 gtr
T04GTR: 11.7 @ 116mph r32 gtr
wrxhoon: 11.8 @ 117mph r34 gtr
hot53x: 11.961 @ 112.77mph r32 gtr
Blitz: 12.0 @ 111mph r33 gtr
benm: 12.3sec @ 113mph r32 gtr
OFENSV: 12.123 @ 114.50mph r32 gtr
hanyou: 12.427 @ 111.95mph r32 gtr
JET-32R: 12.49 @ 106.66mph r32 gtr
Morgs: 12.53 @ 111 mph r32 gtr
GTRsean: 12.5 @ 116 MPH r32 gtr
GTR-27L: 12.7 @ 105mph r32 gtr
MIKE_R32_GTR: 12.851 @ 105mph r32 gtr
GTS-t/ GTT
MR331307: 10.8 @ 128mph r33 gtst
2RISMO: 11.662 @ 118.3mph r33 gtst
RNMENC: 11.75 @ 121mph r33 gtst
itboom: 11.8 @ 122mph r33gtst
ECR033: 11.945 @ 118.27mph r33 gtst
DoughBoy: 12.0 @ 123.7mph White car r33 gtst
DoughBoy: 12.1 @ 119mph Black car r33 gtst
88silhouette: 12.119 @ 111mph r31 sil
OFENSV: 12.175 @ 118.14mph r33 gtst
legend01: 12.220 @ 111mph r32 gtst
qwikky: 12.3 @ 109mph r33 gtst
moanie: 12.504 @ 112mph r33 gtst
abobob: 12.764 @ 106mph r34 gtt
mass iv: 12.91 @ 111mph r33 gtst
Guilt-Toy: 12.98 @ 108mph r33 gtst
yogi000: 13.1 @ 108mph r32 gts
ru3-29T: 13.3@ 105mph r33gtst
spx25t: 13.354 @ 103.23MPH r31 25t
race_snooze: 13.4 @ 111mph r33 gtst
cerci: 13.522 @ 103mph r33 gtst
GTshortie: [email protected] r33 gtst
kennedy: 13.615 @ 102.42mph r33gtst
silver gts-t: 13.62 @ 103mph r32 gtst
trust33: 13.6 @ 102mph r33 gtst
cuong nguyen: 13.761 at 106mph r32 gtst
RedDrifter: 13.7 @ 105 mph r32 gtst
cohen20: 13.7@?? r32gtst
JAS-25T: 13.8 @ 99mph r33 gtst
burnsie: 13.900@98mph r32gtst
SECUR1TY: 13.902 @ 101.36mph r33 gtst
Shonen: 13.934 @ 97.4MPH r34 gtt
JeeTeeEss25Tee: 14.01 @ 100.58mph r33 gtst
nath95: 14.04 @ 99mph r33 gtst
MaTBoY: 14.09s @ 99.55Mph r32 gtst
Siddr20: 100.15mph r33 gtst
mr moo: 14.191@ 96.76 r33 gtst
mike1987: 14.2 @ 97mph r32 gtst
jf R33: 14.258 @ 100.66mph r33gtst
tomm0: 14.3 @ 98mph r33 gtst
raz0r$harP: 14.516 @ 95.98mph r33 gtst
evil_weevil: 14.5 @ 94mph r33 gtst
d00dz: 14.53 @ 102.5mph r33 gtst
Tebie: 14.572 @ 94.24mph r32 gts4
sindows: 14.8 @ 96mph r33 gtst
the R32: 15.0 @ 101mph r32 gtst
Other
Boosted Zed: 10.709 @ 139.67mph 300ZX
Barry: 11.1 @ 123mph datto 1600
ido09s: 11.274 @ 121.79mph S14a 200SX
NBP: 11.8 121mph rx3 13bt
bmxwrx 12.4 @ 112mph MY00 WRX
TommO: 12.6 @ 108mph Evo VIII MR
DVS>VLT: 13.6 @ 104mph VLt
wokburner: 13.02 @ 109mph 300ZX TT
BLISTIC: 13.0 @ 109mph 180SX
PORTS: 13.433 @ 105.39mph z32 300zx
Felix st: 14.7 @ 94mph 98 Honda Integra VTIR
Will be updated. :laugh:
Edited by johno_shaun
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
