Thanks guys. No new mods since my last 13.4's, just practice. Still auto.
This is from the other thread I started:
I've been quite frustrated by my bad drag times so far in my car. Even when I had the stock turbo I seemed to be way behind the pack. I've been to a few wednesday night street meets and in my unprofessional opinion they suck for everything bar socialising. Too many cars, not enough runs, too many rotaries dropping oil all over the track.
I figured what I needed was a private track day with lots of runs to practice so I went to the V8owners track day on sunday (I was invited by the organisers who know me) and I practiced.
First run 13.4
Second run 13.3
Third run 13.2
Fourth run 20.4
Fifth run 13.08
Sixth 13.4
Seventh 13.2
Eighth 12.9!!!!
At this point I rang 2rismo who gave me a little tip and told me I had a 12.8 in it. I didn't believe him and consequently stuffed the next 3 runs up.
Next I started paying attention and I got about 4 12.8's and then 3 12.7's each time dropping a few hundredths on my ET. My MPH on my final pb of 12.764 was about 105.xx but interestingly I got 107.95 and 107.88 on other runs so maybe I've got a 12.6 in it?
I've got steel wires sticking out my tyres now and a grin from ear to ear. I made lots of smoke and put some of the V8's to shame, although one guy made my 190km/h burnout over the start line look lame by burying me in his tyre smoke.
Thanks to 2rismo for the tips.
http://www.skylinesaustralia.com/forums/in...howtopic=119940
First run 13.4
Second run 13.3
Third run 13.2
Fourth run 20.4
Fifth run 13.08
Sixth 13.4
Seventh 13.2
Eighth 12.9!!!!
Congrat's on the ET improvement!
Peter and Duncan are a well organised friendly bunch who know how to put on a good day at WSID. I went out in March with them, lots of fun.
First run 13.4
Second run 13.3
Third run 13.2
Fourth run 20.4
Fifth run 13.08
Sixth 13.4
Seventh 13.2
Eighth 12.9!!!!
Good stuff mate.
I guess Practice does make perfect.
Congrates.
Great stuff mate!!!
theres an LS1 private day ive been invited to....how does the car hold out on a full day of drags?
better than a track day?
i.e. less or more wear and tear?
    • Hard to find reliable dyno results that help my selection   Thinking G30- 660 twin scroll 1.06   Problem is my current setup isn't imo terrible. This is the genuine flog it at the track tune so there is a few kws in it but pulled for track safety   Non VCT RB25DE home built and has baby 256 Poncams, 60mm throttle body. 90mm exhaust and decent ARC cooler with Emtron KV8 Would like to break 400rwkws on 20psi and want a bit more through the 4,000rpm range. New setup needs to beat attached dyno
    • Hey y'all, had some bad ball joints in my tie rods, so figured i'd just replace both inners and outers.  Went with the high-misalignment system from GKTech. My car's lowered so figured why not. M14 Super Adjustable Inner Tie Rod High misalignment S13 240sx/S14/S15/Skyline tie rod ends (12mm/14mm) Welp, took over a week to get the job done, but finally did. Took it on the maiden voyage today and... - The OE boots do not sit properly on the new inner tie rods - If you look at the photo in the link above, new ITRs are basically threaded all the way through the length of them, so best I could do was tighten the boot down with a screw-down hose clamp onto the ITR's threads. - There is a "whoosh"ing sound every time I turn the steering, seems like it could be coming from the air moving into/out of boots. Concerning, bc it'll likely pull in nasty shit from the outside when I turn... namely thinking of moisture. - Looking at the rack from the back of the car, under it, the left tie rod is straighter than the right. Right droops down a bit. - My alignment is way outta wack, that's expected. Taking it to get an alignment as soon as I can. - The big thing is that the steering isn't really "springing" back like it used to. Wondering if there's something tied to pressurization of the system that I managed to f**k up. This was supposed to be a 20 min job... why doesn't anything ever go right with these cars?
    • Thanks guys, toruqed down to 65ft-lb, or 88 n-m.  Now have other problems, will chronicle in another thread. You guys are the best, thanks for all the ugga duggas.
    • R serious becoming more of a weekend cars or collectors cars there are less on the road these days , but you sometimes come by one or two . we might have to start spotting the V serious to make up for the gap.
