they buy u what u want ;) *big hugs to the other half* :D
Inside the box -
Parts laid out -
the body (fresh out the box unpainted still)-
close up of parts -
the instructions -
I bought some paints i didnt have so i can paint it soon (ive done models in the past).
The detail is pretty good, it has a full interior (dash etc.) and rubber wheels etc...i can paint it my choice of colour, but im going for the metallic black.
i'll post pics of the build. :drag:
https://www.sau.com.au/forums/topic/111262-bithrday-prezzies-56k-sucks/
I bought mine from Hobby Habit on Main Nth Road.
They have a large range of others (which ive got my eye on) including 33gtr's, Pennzoil Nizmo, Calsonic, 34's, 180's, gtst 33's, silvias (s13/s15). The damn paint costs about the same as the model was to buy, but if you have built some in the past it works out u only need a few colours at a time.
Go to the tamiya website to see the full catalogue.
Oh yer, Hobby Habbit have one i saw im getting next - The Homer (includes a small homer) :drag:
How much are they?
The model as you see it is about $34
If you dont have the paint, it becomes expensive, as it uses 18 different colours. I only had to buy a few colours as ive done previous models in the past, and the more kits u buy later, the less paint u need to buy.
Happy B'day. :)
Looks nice, when will you get around to putting all the bits together?
Not going to be like the 'real' R32 is it... You know.. that hks manifold sitting shed.... the bonnet and guards that are sitting in the shed.
hehehe lol
Happy B'day. :mellow:
i had a awsome model of a purple 34 gtr on my 21st bday cake that my mum got, its pretty detailed, and cost like $80 from some hobby shop, ill post pics when i get a chance :) (i tried 2 return it n get blue but they said no :happy: )
Nice present, looks nice. I thought I would let you know that I have a !/12 scale nizmo R32GTR model. It has rubber tyres, working steering, mesh grill, hinged doors,turbo's brake disc's and even metalic badges . I have been to lazy lately to even start to assmble. lol This one was $300 though and limited to a few hundred models. I got it for my birthday to.{two years ago}This one is mainly assemble with screws and springs and will take time to assemble {many hours} .Its about 375mm long. Got it from complete hobbies main north rd brahma lodge.
I have other models to finish first 1\32 A10 thuderbolt , 1\35 apache helicopter etc .
If you want a look, I might be able to post pic's or maybe catch up with ya so you can have a look.
Any way nice present! :happy:
Straightline Automotive on Port Road also has these Tamiya models, I think he has a couple of 32 GTRs down there at the moment. They sold like hot cakes at the last Extreme Horsepower show.
He also has some of the Initial D already built black 32 GTRs which are pretty hard to find if you can't be bothered building one up.
I just got a different brand 32 GTR that i am building up. Mine doesnt have an engine in it though :D
Here are some pics of a 2004 34 Nismo Race Car that i built last year
Edited by Whiplash
  • 1 month later...
couple of update pics :)
Havent been working on it much lately....but meh...
(images attached for now as sau hosting is down atm) will edit later...
Engine bay still have brake stuff to go in, and painted.
Body is being sprayed and decals put on the exterior...as well as lights etc.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
