i have a stagea with an r34 rb25det
after the ecu was disconnected, then reconnected, the car wont start. the engine is cranking but there is no spark. the fuel is there. just that the coil packs do not operate when i crank the engine.
any ideas guys?
an anti theft system of some sort? im stumped.
https://www.sau.com.au/forums/topic/111314-car-starting-problemshelp-needed/
try actually pushing the plug in harder
i found once i didnt put the plug back well and the 4wd/abs/etc wasnt working. Could be an easy fix?
Otherwise, not sure what fuses there are for the coilpacks.
Maybe some fool disconnected the coil packs? The connector is at the end of the rocker covers near the fire wall.
the coil packs have power, just dont have power when i try to crank it :happy:
i'll try pushing the plug in harder but im pretty sure its in securely.
i need to get the car fixed by 9am tomorrow morning if im to make it to the "Vehicle Identification Inspection"
otherwise i'll have to rebook it and wait another week before it gets on the road. :)
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
