  • Replies 82
umm...i used it so long ago, havent used it since...but like i said, i dont know how to use it properly, so i basically found the MCG in the city, or any other big landmark you know of...then i basically scrolled my way across the maps until i found the freeway out of the city towards geelong...took my hoppers crossing exit and basically scrolled to my house...not the easiest or quickest ways to find stuff i'm sure, but it worked. lol
is the images upgraded all the time or are they the same permanently?
They started taking them in 2001 and finished the earth in early 2003
Now they are using heaps of different satalites to take pictures which is why you see down the bottom of the screen the rights change eg "Google Earth 2006"
Well regardless of how cool all that is i found my banana parked out front of a friends house :wub:
It is a little hard to see but it's there!!!
Matt, Sorry to piss on your parade, but you do realise that these maps are 2 - 3 yrs old (for obvious reasons - ie nasty people who like to plot mayhem).
If you don't believe me, think of some big construction project or new housing estate that's less than 2 yrs old and see if it's there.
actually ur wrong, i can c the constuction for the albury bypass which started 8 months ago
also the epping bypass is in there also :wub:
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
