Hi all,
I installed my SAFC, but ran into some problem, as described,
Idling is weird, and when i accelerate, its feels like its hesistate, and can NEVER rev pass 2500RPM.
smoke in the exhaust alot as well.
I did ECU diagnose, and got code 12: AFM circuit
I am not sure if i blown the afm circuit or the inside the ECU,
anyone know how can i get it fix?
or any place in Sydney? i can take them to?
thanks heaps!
darrien
https://www.sau.com.au/forums/topic/111354-installed-safc-something-wrong/
Double check all the wiring to make sure you've done it correctly... failing that make sure the "setup" process was done right - I remember having this problem as well, all it was was a wrong setting whilst doing the setup stuff.
If it still doesn't go good after, send me a PM - you can bring it down to our workshop - we've gone through many SAFC installs now :D
i fink i will bring it down,
because at the moment, i cant think of what i did wrong!
i need another opinion! i read the instruction very carefully and done it carefully!
the only thing i can think off is,
I the turtorial section: they have ECU pin layout different from the Apexi ecu layout.
They ground wire in the turtorial is PIN 60, where as the ground in the APEXI website is pin 26 (next to air flow signal).
Initialy i wire it to the wire #60, but then i change it to wire #26. but problem still there!
Oh,
i already did posted it on the Skyline relate forum. In similar topic.
I took raz0r$harP advice.
it just when i conect the wire, i pulled them bit hard, and the pin that connect the ecu harness to the ecu pin loose, caused no conections.
Edited by RBFIRE
