G'day,
My skyline is running terrible, stalling and struggling to restart and this ones has got me stumped. The car seems to have a rev limiter of 2500? (AFM?) it really struggles to climb revs, and many times will stall and not restart. The strangest thing is the car will run perfect for the first 5 mins then start bunnyhopping all over the place like its running out of fuel. Give it a few mm of throttle and it dies in the arse and bunnyhops.
Any help is great the only thing left is the AFM, so how can I test it?
Cheers heaps
https://www.sau.com.au/forums/topic/111373-need-urgent-help-for-rb20/
Try taking the AFM out and cleaning it with metho or something, I usually use a gas lighter on it as well to burn the metho off -may be a bit extreme but it seems to work for the last ten years of doing it every year.
Also change your fuel filter if you have not done so.
Seems to be when it gets hot that you have the problem so that indicates maybe a water temp sensor??
Yeah thanks mate, fuel filter was changed and whole fuel system was flushed out and a new tank was put it, so at least I know it's not that.
Yeah will give the AFM a better clean this time, but it was crystal clean last time was cleaned only 2 months ago.
Will check the temp sender again
I'm sure some other poor bugger skyline owner has had this before :wub:
Cheers
Yeah iv had almost the same problem. not as extreme as what your getting though. I took my car to a few different people and no one could give me very good answers. My car seems to of fixed itself though... wierd.. hasn't happend for a few months now..
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
