SUNDAY 2nd MARCH **HARRY's 4 PIES MEET**
  • Replies 110
Nah stuff the hotdog....
Stick to the Chicken pie, with Mash and Gravy with abit of tomato sauce.... Hmmmmmmmmmmmmmm
U should have came with us afterwards, there was heaps more
FAT cars later on......
You should make this a regular Sunday outing man....
i'm in for that!!! i dont have uni till about 4-6pm on mondays anyway :P
Originally posted by [ryan]
lol
that's the same ranger who ALWAYS comes over when there's a meet. The other Holden-loving bogan ranger didn't make an appearance though, i was surprised
You could hear on the ranger's walkie talkie, "My BOV is bigger than your BOV". BAHBAHBAHBAHAHAHAH
Sounds like you all had fun, pity I couldn't cruise on but I'd have become a road toll statistic with so little sleep. Kicked myself all the way home!
That GTR ripped. one of the quickest cars I've ever been in! Would have liked him to really open it up but it wasn't the place to do it and believe me that car had soooo much more to give!
Good to see new people too, the more he merrier!
Sorry to all who i didn't say hi too.. Was a bit edgy so tried to
stay away from people...
To get to Harrys.. On george st after the cinema's turn right.
goto the end
turn left.. then turn right straight away.. go down the hill.. (*)
i think after two sets of lights there will be a farrarri store to you
left.. Its on the corner.. You have to turn there.. go all the way
down to the end.. turn right.. and your there..
or you could continue from (*)
head down towards the coke a cola sign, turn left and drive
through the cross.. go all the way to the end.. and turn left
drive down about 500 metres and your there.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
