Hey mate,
just had my line moved from Vic to Perth using an enclosed service. Was done by TNT and I'd highly recommend them. Car is low with some fibreglass hanging off the front and it arrived in the condition it left in. Also car was as clean as when it left.
Probably not the cheapest but there are a lot of cowboys out there.
I would recommend TNT but then I work for TNT.If you want to get idea of prices call me on 1300 655 594 names Rob.
for legal reasons I cannot put up prices
sorry
but call anytime between 9-5pm Sydney time MON-FRI
just mention you are form SAU
Edited by spx25t
yea i would definately recommend TNT
we used them for my otha halfs 32
they brought it to our front door from Adelaide
and it was reasonably priced
plus we could track it all the way
if you want the best service for your buck use em..
i cannot fault them in anyway
I have used tnt melb to perth very good service. i have used them the transport cars all over aus.
another one is trewintransport.com.au
toll is another but I found them dearer than tnt
I would allow 1200-1500 per car its a long way at least not sure on pricing. melb-perth was 800 or so.
cheers
meggala
also remember you cant leave stuff in the cars with most transporters
Check all the insurance and that kinda thing, Whilst my r32 was being transported it was stripped and rocked up in adelaide minus indicators headlights + interior bits and pieces. I was very upset with the company to say the least. They evetually paid for it. Its a well known company. If youd like to know who it is PM me.
  • 8 months later...
got my car down from melbourne to brisbane from a company called CAR MOVERS...for $550, in 3 days...
got it down from the car carrier and the car did't move!!...can put to any gear but no drive at all...
so have to get a new clutch from Tuned in Brisbane!!!
The clutch was 100% ok when i gave them the car.......but no point arguring as i can not prov my point.... (Note your KM when y give the car, let them know that !!!)
just use TNT vehicle logistics.......i didn't use it cos it a BIT more.....but paid for my mistake :)
so free advice people....
TNT is by far the most reputable company i could find when i called around in mel, Everyone else :P well.....you know what happen to me !!!!
PS: I am not assuming...all other car carriers take cars for joy rides by the way...so dont bag me...
HI I work for TNT Automotive Logistics
actually as of last Thursday the company has now changed name to CEVA Automotive Logistics
But you can call 1300 655 594 and ask for Robert and I will be able to give you a idea of costs.
Mention you are from Skylines Australia So I know who I am talking to
Cheers
Robert
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
