Having my RB26DETT rebuild by a company that doesnt really know those kind of engine. They have the Bible, and they are following the book. They have really good mechanic, so I trust them no to do anything stupid.
But is there anything that I should tell them to not forget or to lookout for?
I heard something about the torque plate warping? I dont have any info on that. Does anyone know what that is?
Is there anything I should know to prevent any kind of surprise?
https://www.sau.com.au/forums/topic/111420-things-to-know-when-rebuilding-rb26/
You should have taken it to someone that has built them before .
What kind of built are you doing ? You normaly rebore and hone the block with a torque plate .
Are rbs really that different to any other motor? surely a bottom end is a bottom end?
Of course they are not Duncan but if you take to someone that does them all the time, they know what to look for and they can do it fairly quickly . At the end it will be cheaper and better because they are geared up for it .
Oil control can be a problem, but you havnt specified very much about the build. Is it a standard part rebuild? How much power are you after? What is the engine being built for? Will it see track/drag/drift or street?
Either way a good start is here
http://www.skylinesaustralia.com/forums/in...howtopic=110680
Im rebuilding the bottom end:
.50mm oversized pistons,
Main bearings,
Rod bearings,
N1 Oil pump,
1.2 mm HG Nismo,
I'm just looking to rebuild it to standard specs.
The machine shop that im dealing with never touched a RB motor cause its not usual to see a rb here in canada but they do alot of dragsters and kinda like nascar motors. They probably know what there doing. But I wanted to know if there were anything (tips) for rebuilding the rb26?
Thanks alot for the info.
depending on what pistons you are using
just make it clear that they get the piston/bore clerance correct
probably the most critical part of the build.
and yes torque plate honing is recomended(dummy head bolted to the block)
If it is a standard rebuild to basically stock specifications, the only requirement is good workmanship and care. Nothing particularly different or difficult to any other engine.
If a lot of non standard parts are being used, it is a completely different situation. Many genuine racing parts are simply not suitable for a long life road engine. Special engines require special care and expert knowledge in selecting and fitting non standard parts.
With the upgrade of oil pump to N1 i would install a tomei oil gallery block restrictor , they are cheap and very easy to install and just help control oil flow to the head.
If you haven't bought your head gasket kit just buy tomei metal head gasket kit as they have one in the kit or there like 500 yen on there own
On another note are you doing any work to the head if so the exhaust valve clearances might catch you guy out as they run very loose clearance because of the special valves (they feel f..ked even when there fine)
pete
pete
I will install the tomei oil restrictor, and I have the nismo gasket kit with the 1.2mm steel HG.
Thanks for the info on the valve clearances, we were kinda stuck on that, trying to figure why it was so loose.
Is there any other information about rebuilding rb26 that you know of?
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
