I have them in my car and the improved handling is noticable, yet I meet other members and they haven't heard of them, its a bit hard trying to describe them because I really dont know what they do, although I know the difference of before/after.
BEFORE
When entering a corner I could feel the body move/angle over to the opposite of travel and then the shocks/springs dampen this effect.
AFTER
No body movement just springs/shocks doing their thing, still has body roll (until whiteliners are in)
So I assume that the pineapples fill or harden a soft (family car) spot in the setup, can somebody fill in the gaps for me? :wub:
https://www.sau.com.au/forums/topic/111428-pineapples/
Did you put the 4 in or the 8 in. Are yours poly or aluminum?
I have 8x 4-5mm thick aluminium ones in, and I want to pull 4 out to see what it does. I dont think the 8 are really helping, just contributing to in cabin noise from the diff.
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2054983
sell em here for $99 per set, Bee R brand
http://www.otomoto.com.au/beer.htm
from the website:
Adding these bushes to the rear suspension cradle in any RWD Nissan (and GT-Rs) from 1988 to 2002 reduces cradle movement dramatically to give a more consistent, predictable feel to the rear end, which is especially valuable for drifting. By altering the static angle of the cradle, pineapple bushes also promote rear suspension squat for greater rear grip.
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2055222
I wonder if someone can answer a related question for me on this.
There are 3 setups you can use pineapples for, Drift, All round, Drag
I think sydneykid posted a "where to install them" for each setup, but my question is...
The pineapples i bought came with 4 small rings and 4 large rings, if i'm setting it up for drift, do i use 2 small ones and 2 big ones and just not use the other 4? or do I use all 8??
And to anyone who uses them for "drift", how much does it effect oversteer? I'm wondering if i should just use the 'all round' setup for them, becuase i'm not having any major understeer problems, and i dont want to make the car too spin-happy!
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2057706
Apparently the setup for drift makes it stupidly slippery. Best to set it up for allround if you just want the subframe firm, or put them in with the Noltec subframe bush kit to set the subframe for traction.
4 small ones for traction according to whiteline.
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2058009
I dont remember what was put in mine but they are Purple and on the bottom of the subframe so its all round performance, nolathane bushes went in as well.
So I can say to the peoples that they reduce the cradle movement and give a more presice feel to the rear end.
Thanks guys
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2058256
Be carefull, the article in HPI/ZOOM is missleading.
The Otomoto kit only has 4 bushes. 2 large (not split) and 2 small (split). When you use the 2 small bushes below the subframe you have to tie wire them otherwise they WILL fall out.
As you can see from the instructions (copy following) the Whiteline kit has 6 bushes, 2 large (not split), 2 small (split) and 2 small (not split). The 2 large bushes do not need to be split as they are mounted below the subframe. The 2 small split bushes are for fitting above the subframe without removing the subframe from the chassis. The 2 small non split bushes do not need to be split as they are mounted below the subframe. Since they are not split, they WILL NOT fall out, ie; they do not need lock wiring
For $5 extra I would buy the Whiteline kit, get the extra 2 bushes and avoid the need for lock wiring, which is not a permanent solution.
:P cheers :O
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2058355
I have 8 aluminium ones in (c type), and to tell you the truth - the noise does not bother me at all. You certainly notice it's there, but what's a little bit of noise on a sports car. If you don't like noise then you should get the polyurethane ones.
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2058461
no offence Syd kid i have the otomotto kit and i have 2 large split and 2 small non split
Interesting, the sample kit I have has 2 large split and 2 small split
If the 2 small are not split, how did you get them above the subframe?
Remove the subframe?
Or cut the bushes?
:P cheers D
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2058460
ok, thanks for the replies, but i'm even confused now...
the kit I have (alloy pineapples) has 4 large split, and 4 small not-split... (the smaller ones are the thicker ones yeah?)
so go figure!!!
I might give them a try in "drift" mode and if it's too spin happy i'll change them to "all round"
also, which way around do they go?
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2058466
http://www.driftshop.com.au/suspension_files/subframe.JPG
^ these are the ones I have....
is install different from the whiteline ones? I need to know the correct layout for "Drift" and "all round"........
Edited by MerlinTheHapyPig
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2058476
The whiteline ones are urethane, and are there to change alignment of the subframe.
The alloy ones u got there are designed to crush up the std bushes to stop flex in the subframe, without changing alignment of the subframe.
In your case i think the c ones go in the top, and the others go underneath, so its meant to fit without removing the subframe.
https://www.sau.com.au/forums/topic/111428-pineapples/#findComment-2058495
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
