So looking at the SK pic, in standard trim, the subframe floats up and down on those mount points, and the pinapples fill a that gap.
If you get Aluminum ones, sound is tramitted through the frame.
For all round performance use the bottom ones (non split)
For drift tilt the diff back using btm front, top rear.
For drag tilt it forward using top front, btm rear.
"I have the otomotto kit and i have 2 large split and 2 small non split"
This would be a kit designed for drag then.
The whiteline doesnt have the scope for drift? and if you put all 4 budshes in the rear it is a marginal drift setup?
EDIT! The whiteline doesnt have the scope for drag?
couldn't remember if you had the pinapples or not but from memory your car was quiet, handled awsome and had the same firm ride in a straight line as mine with its standard springs and uprated shocks (on car when bought). Cheers for letting me know you did have them for our spin :thumbsup:
P.S. enjoying the job? had to do a couple of your call outs. Sick of being told "can't make it" yet?
Edited by ellie
Not so, you put the small split rings above the subframe at the rear and the large non split below the subframe at the front. This give max antisquat which reduces the rear end grip, making it the ideal setting for drift. It's the bottom left hand drawing in the instructions.
:thumbsup: Cheer :)
I have most definitely used the drag setting (maximum squat) on a few cars that I have worked on, as well as my own. The usual improvement in 60' times is 0.15 second from the subframe alignment.
That setting is the lower left in the instructions (maximum traction). With the small, split rings on top at the front and small, non split rings on the bottom at the rear.
:( cheers :)
most people i've spoken to using them in drift cars, go for either "All Round" or "grip"
As someone mentioned above, and has been confirmed with a few people i've spoken to who have used them in "drift" setup, they are stupidly slippery and becomes more of a hinderance than a benefit if the car is properly set up in the first place.
Any problems with understeer or problems loosing traction for drift should be overcomed using different wheels/tyres or different stabiliser bar settings.
how long generaly should the whiteline pineapples last for ??
i got mine about a year ago but i think there starting to die now...
that clunking noise has kinda come back now when i turn and stuff..
hmm maybe ill take em out and see if there cracked or something
  • 1 month later...
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
