Hi Guys,
I need to install my FMIC and will need to cut out the front intrusion bar (to fit my Hybrid Intercooler as per the specifications). The car will have to go through the pits after all the modifications and i want to make sure that i don't get pinned for having a modified (cut) front intrusion bar.
I don't think they will look.
Or should i wait till i get it over and then finish of the intercooler and piping. Until then i will have to re-install the old intercooler from my R33.
Advice would save me time and mucking around.
i have an r33 series 1.
https://www.sau.com.au/forums/topic/111437-is-it-legal/
yes its illegal. but in most cases they dont look.
i was driving around with no front bar, and most of my front bar support has been chopped away to fit my fmic and front bar. got pulled over and they didnt say anything about the amount of metal i took off, but how the exposed corners of it could cut someone that walks past my car.
i wouldnt risk it unless you had a front bar on. they cant ask you to take your front bar off to check can they?
https://www.sau.com.au/forums/topic/111437-is-it-legal/#findComment-2054877
  • 3 weeks later...
my mate got pulled up and he had cut about 10mm of o get the cooler in and they just put their hand up there and felt that it had been cut and they told him he had to reinforce it. i'm putting a new bar on where i have to cut half the front out so i'm making a bracket to go around the bottom so hopefully they will let me off
https://www.sau.com.au/forums/topic/111437-is-it-legal/#findComment-2096887
Doing any modifications to ur car is defectable because it is changing what the manufacturer inteded.
Meh that isnt going to stop anybody from modifying their cars.
stuff like that you just have to take a gamble, just do it neatly and they shouldnt pick up on it.
https://www.sau.com.au/forums/topic/111437-is-it-legal/#findComment-2098888
ive chopped my front intrusion bar for my fmic. i'll be welding some extra steel from the side bracket thingo to the front intrusion bar, then a flat bar across to give it some more tensile strength.
ill post pics once its all done :(
https://www.sau.com.au/forums/topic/111437-is-it-legal/#findComment-2099658
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
