Wrecking ser1 r33 gtst Melb all parts must go!
  • Replies 224
Streamer - I have just the left shock and I am not separating the turbo and manifold sorry
Peter Behrens - Entire body shell i.e. stripped right down? The chassis front right is lifted 20cm higher than it should be and the firewall is slightly buckled on the right. Everything else is like new
Sciby - the drivers side window motor u r looking at 150, let me know what u think. I'm selling the door interior as one bit sorry.
hehehehe - boost solenoid $20? i don't really know what they're worth - always welcome to come have a look at what i've got though, and i'll try and find the solenoid 4u
naveed - plastic strip the battery is behind? i'm not sure what u mean but I know I haven't sold it! I have it if u can explain a bit better?
WLD747 - I have all of these parts. give me a call whenever and we can discuss
hippy - I have the rear bumper support. Let me know when u want and do u want it sent to SA?
Any questions or if u guys are in a rush just call me 0401 598 511
or direct email [email protected] - cheers Ben
 Share
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
