  • 3 weeks later...
  • Replies 224
im interested in the little plastic piece for the horn that is behind the steering wheel. im talking about the ring with the flat cable attached. mine is broken and these are pretty hard to find here in the US.
thanks
clay
have no radiator, front quarters or exhaust. all other parts must go this month. I still have engine, gear box and complete interior/exterior in top condition. the car is black
make me some offers!
pics can be sent on serious request when I have time. cheers
Looking for YOKE to go into R33 GTS 25t gearbox.
Will take whole tailshaft if necessary, but only need front section.
Email me on [email protected]
Thanks,
Dennis :ghost:
  • 4 months later...
Man looking for the driver's side window panel, i'm been broken into.
How much for it, i can cover COD.
The window panel is sold - these are the parts I have left guys....
REAR BRAKE SET
STARTER MOTOR
MASTER CYLINDER/BRAKE BOOSTER
IGNITOR MODULE
ECU
CASTOR RODS (PAIR)
FRONT LEFT LOWER CONTROL ARM
AIR CON CONDENSOR
HVAC FAN BLOWER
HVAC UNIT (HEATER CORE, NO LEAKS)
PEDAL SET
PETROL TANK
GLOVE BOX
DASH PAD
CENTRE CONSOLE WITH LID
R + L DOOR TRIM (NO DRIVER SWITCHES)
R DOOR
R MIRROR
STEERING COLUMN COVER
BOOT RELEASE CABLE
BONNET RELEASE
FUEL PUMP
OUTER PILLAR TRIM
FRONT HUBS
PRESSURE PLATE
ENGINE WIRING
WIRING LOOM
POWER STEERING RACK
STEERING COLUMN
REAR ‘SKYLINE’ SIGN
TOW HOOK
ALL SEATS
R REAR QTR PANEL
L REAR QTR WINDOW
CARPET
FRONT WIPER MOTOR
REAR WINDOW
SIDE INDICATORS
SPOILER
DIFF
INTERIOR LIGHTS
INTERIOR PANELS
OTHER SMALLER BITS AND PIECES
My no. is 0401 598 511
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
