I just got a report back on an R34 I'm looking to purchase. The report said that the turbo makes a whistling sound under boost.
The guy who performed the inspections knows skylines well and owns one himself. He said this is not normal but has heard it once before on another skyline.
Is this bad? Or does it not matter? The car also doesn't perform as I think it should but then again it's only running the stock exhaust and I'm used to my R33 with a full 3" system.
Apart from this the car is in excellent condition and has done few km's.
The mechanic said he 'doesn't really know' if it's a bad thing or not.
Any turbo gurus? Does the turbo have a clipped fin and is stuffed or what?
you need to look at this logicly ....
the noise will be either air or bearing ... if its air then that can be assesed as maybe a small leak which would could easily found with a bit of testing ... mine was a flange leak
If its a bearing then thats a bit different ... some bearings will whistle for ever never being affected and some will groove along untill they have no slippy stuff left and seize ...
compared to the rest of the car the turbo is condidered a bolt on so i say if its the right price go for it and strap on a better huffer when you can .....
Our R34GTT did the turbo whistle as soon as we upped the boost even a little bit. The Stagea is the same. The R33GTST doesn't and its turbo is a lot older than the R34GTT or the Stagea. Maybe something to do with the Hitachi turbos, plastic compressors etc.
:P cheers :rofl:
ive driven about 10-15 r34 gtts, and i have not heard one whistle.. just giving my input :)
nfi if thats a good or bad thing.. maybe its so u can woof whistle at girls without having to be louder than your exhaust or sound system :O
edit: bad grandma.... grammar :P
Edited by illusiVe
just picked mine up on tuesday... on stock boost, mine didnt whistle.. just the compression sound of air rushing.. but i put in a manual boost controller, bumped high up to 9psi... and it sounds fine getting there.. but it starts to whistle when it manitains 9psi from say 4k-7k
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
