Hey
just wondering if there is anyone that drifts there r33 gtst
Just wanted to query what power output are they making, and what mods they have done
I have seen the gold r33 ( with the PPG.COM.AU on the side), thats a competitor in the drift nationals ( was or still is)
and has alot of mods .
Not going to be going that far.
Im talkin about ppl that have minimal mods, that are in the drifting scene.
and how it performs on the track.
I have
PFC
FMIC
AVCR
Strut Brace
KYB shocks and lowered king springs
z32afm
Hiflow turbo (270 thrust bearing, bush bearing)
Walbro fuel pump
CES Racing Split dump
I havent done drifting b4, but want to get into it, and have a go
Thanks
Any info would be good
https://www.sau.com.au/forums/topic/111482-any-r33-gtst-drifters-here/
Hi Mate,
I drift mine... currently building it into a bit of a weapon to go take on the PPG Gearbox car, but once it was a little more stock than yours.
The biggest question that I would first ask before I offered any advice would be is it your daily driver?
Dan.
well at the moment, im only using the car on weekends
i have a datto ute, that its getting a ca18 put into it
I would like the r33 still to be a decent car to drive on the street
but no, i dont drive it everyday . Just on weeknds
i wouldnt imagine that it would be
im not wanting to go as far as, drift comps every weekend
just wanting to have a go at it, and wanting to speak to ppl that have minimal mods done and see how there r33 gtst goes and performs.
anything that they have felt or seen, or heard that r33's need improvement on to have a decent drift.
hey,
i drift my r33
mods are:
Stock Turbo
Stock Dump Pipe
Trust front pipe + Hks cat-back
D2 Coilovers (unknowned spring rate i think 6,8)
Profec A ebc (i've only run 0.6bar on drift days)
Air Filter
Fmic
Tomei fuel pump
RG castor rods
i still have stock LSD, i run 17inch(235) on the front and stock 16inch on the rear (215/225). I find with the stockers on the rear the car doesnt have much grip, i like my drift setup to be grippy, so i've swap to 17inch on the rear but have yet to drift the car with the 17's
I find wiht 0.6 bar i have enought power to drift, the limiting factor in my car is my LSD and it is very worn and its hard to hold/controll drifts most of the time it just die in the ass and the car goes from sideways to straight in a few seconds.
the Perth drift track has some big turns and i find the bigger turns harder to drift due to the LSD. the small turns are ok
I've link 3turns (smaller one).
My methods of drifting are;
-Brake drifting (larger turns) hit the turn at 140 then hit brake hard let it kick out and try and controll with gas
-Handbrake, this works really well on the smaller turns (never try on the big ones); depending how long you hold it depends on the angle of you drift
or else i just uses the weight of the car, quick turn just a few seconds before i hit the turn works well..
Their is another R33 drifting in perth, the dude has very similar mods to me (i think he may have an aftermarket lsd now not sure) and he drifts pretty good, he has a hicas lockbar and recommends i get one.
So basicly you dont have to have an aftermarket turbo to drift an r33.
I daily driver my r33. The coilovers are abit bumpy (they are track spec d2) but you get use to the ride and can turn them down to soft when your not at the track. Also if you RUN-IN an aftermarket LSD right, it is pretty daily driver frendinly (mate has a kaaz 2way in his 86 and we ran it in just like it told us and it hardly make a sound)
my tips
-2way lsd (kaaz/nismo/cusco)
-Good suspension, something with a spring rate like 6,8 or 8,10
-Hicas Lockbar
- airfilter, ebc, full-turbo back exhuast, PFC, fuel pump (which you have most of)
I also find adding 2 to 3degress of camber to the front really helps (you will need aftermarket upper/lower arms to add more than 2)
castor rods also add more turing in which help (im currently running only 5degress as my tie-rods need to be replaced but once that is done im looking to run 7-8degress)
I run 1 - 1.5 toe out
I have a 350rwhp setup for the car but have changed my mind and not putting it on,as i want to learn to drift good with a stocky power figure (200-250rwhp)
Hope i've help, if you need anymore help, you can pm i will try my best to help you :no:
p.s good to see another r33 get out their and try to drift
Cheers Michael :(
sounds pretty good
so pretty much get, aftermarket LSD, castor rods and aftermarket upper and lower arms. and change camber.
I'll give a crack first off and see how i go, then if i really like it 'i'll start getting some stuff .
Thanks for the info guys
hi all i drift my r33 gtst at wanneroo in perth, if yor looking for s little mods as possible mine is a good example. my mods are stock motor, turbo, ecu, lsd, i have a turbo back exhaust, front mount and heavy duty clutch i only run 0.6 bar of boost. as far as handling mods all i have is a front strut brace and lowered springs and thas it. i competed in the last comp in perth and placed 6th all though i have no idea how. all the best hope you have fun.
a couple of pics for you :sweat:
http://www.highoctanephotos.com/index.php?...bnails&album=76
What Micheal says id pretty close to the mark. :sweat:
If it is a Daily driver I would suggest against the aftermarket LSD, if it is a mechanically locking diff, as firstly they are illegal in some states, NSW I'm am pretty sure is one. A nice tight viscous one will do the trick, or even a new Nissan one.
Aside from that, you should be able to learn to drift with a pretty stock car, but you will eventually be able to outdrive your car.
Learn some techniques for drifting, clutch kicking, handbrake entries, use lower gears until you get the angles to go up cogs. Stock cars can be drifted, if you drive accordingly, and to be honest I am glad I have learnt to out drive my old car set up first, because it has given me a greater understanding of how to drift and I have learnt lots of ways to get it slideways and hold it out!
If you have any specifec questions please throw them up... I will be happy to try and answer them.
Dan.
a couple of pics for you :P
hey michael :P
its michael here too (grey r33 from the drift pract days) if your still interested in the kaaz lsd i may be able to still get you one, send us a pm when you a time.
and good work on the drift comp :)
  • 6 months later...
Hey back again
slowly gettin stuff for my car, and is goin to be setup fairly soon to have a crack at drifting
I have now puchased these things to be put on and have tuned.
z32 afm
oil cooler kit
oil catch can
555cc nismo injectors
aerospeed ex cam gear
nismo fuel reg
new timing belt
hicas lock bar
Hopefully november i'll have all this put on
Currently running 12 psi and have 306rwhp
Lookin at purchasing hks coilovers, lower and upper arms
tie end rods
aftermarket castor rods
pineapples
Then should be pretty much right hopefully .
Any will let yas know when everything is done
  • 3 weeks later...
sounds like everyone is steering u in the right direction.
i try to drift my 33, was doing well until i hit mallala wall like 6-7 months ago. been rebuilding ever since.
mine makes 360rwkw at 1.7 bar, i dont run it that hard tho, i run 1.2 bar and il find out wat that makes wen im a the dyno tuner monday for the final test.
there an awesome machine to drift tho
i have one query about the pineapples
i purhcased a set of Bee*R pineapples from ebay about a week ago
and noticed that they larger ones both have slits in them,
and i think i have read that to install to have drift setup that one of the smal ones have to have a slit in it and the larger doesn't.
Whats the go, will it still work??
Can anyone let us know which way to install them, and any pics?
Thanks
You basicly need to drop the cradle out of the car and put the 4 in the top of the cradle and then the 4 in the under side of the cradle. they stop the cradle bushes from moving. Never done it but that is my understanding.
We refabricated our cradle with no bushes and lots of adjustments.
  • 1 year later...
Very Interesting thread. Its good to see the R33 has got some backup within the drift scene, ive actually come from a S14 and was always considering going back to a S14/S15 Streetcar/Drifter Setup but ive always had doubt with SR20DETs
Ive had my R33 GTS-T and i feel the RB25 is a much stronger/reliable motor and being 6'3 basically a nicer car to drive.
good to see there is becoming more backup within the R33 Drift Arena.
  • 3 weeks later...
Hey sorry I didnt get onto this thread earlier. I owned and competed in my PPGEARBOX/ Martini racing R33. Look like these guys have a fair idea whats needed to slide the big ol boats.
Big rubber lots of grip and plenty of torque is good thing to have. (I ran an RB30 with the 25 head on board)
update on my car ,
havent been able to do much for 2007 (been a shit year), have had some issues with my licence and etc. haha
i am in the middle now of rebuilding a rb25 engine with ACL forged 20 thou pistons, race bearings, and spool rods. Slight port and polish with performance valve springs.
CAr is in the shop at the moment getting these parts installed and made
custom high mount with a gt30r turbo and turbosmart 44mm gate.
Custom plenum with xf throttle body.
car will be finished with these parts on the weekend, then just a matter of putting in the radiator and connecting everything up.
Will put rebuilt engine in when i have sometime.
So i am probably be looking next year to have a go at drifting on the track.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
