Right
the short story
rb26 det (ford xr6t) 1 bar of boost 291rwkw (stock injectros)ill put up the graph but full boost at 4k
unblivebly drivable and im very happy
read the story below if you want teh ful story as why the big injectors didnt go in
adam say with 20psi and the bigger injectors should cruze 330-340rwkw but i must say im happy with it for the moment. he also said it should do a low 11 or a high ten so now i can officially be a massive wanker and say in all my post 10 second potential..... lol.... even though ive never ever been to a drag strip
Here is the rap for Adam at JEM now….. we dropped the car of at 5pm he quoted for 2 hours on the dyno) in the end we left at 3am in the morning with a car that was just shockingly fast (and the sound is awesome) total price was 200 bux more that the initial quote. Adam when so far beyond what a workshop I would consider even remotely reasonable. Great to chat to and a good bloke. If first impressions are anything to go by the dude is a champion and I wouldn’t hesitate to recommend him to everyone in Australia
If you need your car tune he is the man and I must say I never though my car could go that fast on a safe tune at 15psi
Long Story
Ill give ya the full run down this is a 10 hours dyno story of mystery... smoke and mirror. Tits. Booze women and 4 hairy block with huge donggas.
First up a massive plug for Adam at just engine management JEM (I cannot begin to tell you haw far ken good this dude is he stayed up till 3am with us and sorted all the issues)
Right I got there at 6pm last night to find Chris who had put the 660 cc injectors into the beast and the rb25 airflow meters on first start up with a miss in two cylinders
Right so after 20 checks we decided that obviously 2 injector were crapped because the when we put the stock ones in the car ran fine.
So that brings us to 8pm put the car on the dyno attach all the stuff boost fuel pressure adjust the timing ECT
Turn the car on suddenly we realise something is amiss because the fuel pressure reg (which is adjustable) the lowest adjustment we could get was 100 psi so we tested it in front of the reg and behind the reg and deduced that there must be a blockage \in the return to the tank. Turned out to be on of the surge tank fuel lines was kinked (the return one)
So that was fixed
Now was about 9pm anyway Adam ripped it up on the dyno and the car made 240rwkw at 7psi nice but up to it just wanted more fuel and the fuel pressure gauge said the bosh pump was running out of flow or just shagging out so we tested the wiring and had a good earth and good positive anyway we replaced the pump and same dram and she was apples so then we tested the fuel filter every sign line form the surge tank to anywhere for a blockage
We even hard wired the positive onto the pump no luck
In the end we tried the in tank pump and she was good for pressure so we nutted out it was either the wiring on the external pump or by a freak coincidence two dead pump
So next we wired up the pump straight (positive and negative) to the battery with a switch
So final call was the earth from the computer which runs on a relay was shagging out or the power source from the wiring was breaking down under high load
Yea baby full pressure any way in the end because it was 3am and the tune had just finished and we only worked out the problem we only tuned the stock injectors 300rwkw and pulled it back to be safe to 291rwkw at 15psi.
The car used to run 280 rwkw (in tank pump) and was fast
Now the car at 291rwkw is just far ken amazing all boost is in at 4k the power is just crazy it makes 230+rwkw from 4k onwards
It’s got so much grunt it’s almost scary to drive
That’s my story
No vids of burnouts cause we left at 4am and I couldn’t be farked although in third when it comes on boost i does pull a mean high speed skid
Edited by fatz
yea i was hopping for 2nds so im happy
yea in the 31
shame we didnt have time to tune it with the 660cc injectors cause then we could have had some arse puckering power
havent event touched the cam gears yet either(rather spend time adjusting the pro lojics in the sound system)
Congrats man, thats sweet....The more High HP R31's the better!!
Just got 425hp out of the 31 but full boost is not till 7000. 4000 is insane. It truly is Godzilla's daddy!!
G
Edited by GT-PASSAGE
    • R31 boot how I received the sub, cleaned and today new carpet installed. Thank you Solder!!!!
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
