hey guys does anyone hav jumboz springs or know anything about them? they dont have an official web site. i just bought some from a guy on sau, but he advertised them as king springs. king springs are yellow these are green. and i had them shipped down from sydney so as you can guess i wasnt too impressed when i opened the box to find green springs.
they is no part number on them and they didnt come in a box or anything. im only guessing they are jumboz from what other members have told me. i have no idea how low they are or if they even fit my car. the seller bought them second hand from someone else and has never had them on his car. should i put them in anyway?
https://www.sau.com.au/forums/topic/111555-jumboz-springs/
Go to this thread, it shows you how to measure the springs. Then stick up the dimensions and I will work out the spring rate for you. That will at least give you some idea of how firm they are going to be. If you also post up the free height of the coil I may be able to work out how high it is going to be.
http://www.skylinesaustralia.com/forums/in...showtopic=79157
:D cheers :D
Edited by Sydneykid
https://www.sau.com.au/forums/topic/111555-jumboz-springs/#findComment-2057571
hey syd kid
these are the figures i got. the smaller set are 69mm at the narrow end and 98mm at the larger end and have 9 turns igzactly.
the taller set are 89mm at the narrow end and 104mm at the wider side. they are both made from 13mm diameter spring.
https://www.sau.com.au/forums/topic/111555-jumboz-springs/#findComment-2057861
hey syd kid
https://www.sau.com.au/forums/topic/111555-jumboz-springs/#findComment-2057864
hey syd kid
https://www.sau.com.au/forums/topic/111555-jumboz-springs/#findComment-2057866
hey syd kid
https://www.sau.com.au/forums/topic/111555-jumboz-springs/#findComment-2057868
They are progressively wound springs, looking at the pictures and counting the coils, the rates are something like;
Front = 230 lbs per inch soft and 690 lbs per inch hard
Rear = 130 lbs per inch soft and 470 lbs per inch hard
With that amount of progression (5 and 6 coils respectively) they are going to be low, very low. They are also going to be very harsh riding with those sorts of spring rates.
Since they are not Kings as was advertised, I would try and get my money back from the guy who sold them to you.
:P cheers :O
Edited by Sydneykid
https://www.sau.com.au/forums/topic/111555-jumboz-springs/#findComment-2058409
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
