Ok a detailed report of everything that happened has been submitted to the council, and i have had confirmation that it was received. The guy in charge assures me it has been forwarded to the claims department and to get in contact with him in 3 weeks... I wont accept 3 weeks, ill be ringing him first thing monday morning. Apprently if it is established that it IS the councils fault i will have to get 2 quotes for repairs and then submit them and they will cover the costs...
Does anyone know what i will happen if they are unable to match the color? i have a custom pearl and if it dosnt look spot on I wont drop this...
Cheers.
Yeah, you have done the right thing.
This has happened to me twice, once a mower, once a pothole and both times I had my car repaired at no cost to me.
Write a report, get quotes, get photos etc.
Take the car to the council.
You should be okay.
I got my quotes for repairs,
Ranged between $1100-1400.
None of the dudes seemed too sure if they could match the paint shades either... The guy with the highest quote seemed most confident in getting it right though, but the council will just want to use the cheapest right?
do you guys know what happens when you hit something on the road (may have been a huge rock or a piece of tyre, unsure but heard the bang) and it buckles your rim and pushes out your tyre sidewall?! Luckily the wheel got pulled off that night, so it was noticed before it blew out on the freeway at 100k/hr.. :)
But still, unsure of all details except for the exact spot/road, do you think there's much chance of compensation to fix it? Can get photos of the damage but it'd be hard to prove exactly where and when it happened because it wasn't even a pothole and who is responsible for road rubbish/tyres etc?
Hi,
Councils are the worst to deal with, the are slow, so you will have to chase your money.
So just 2 suggestions
1 - Get a lawyer, bill the council for your legal costs as well as the cost of the repairs.
2 The magic words " trash TV", yep Today Tonight and current affair feed on stories just like this one. The angle to push is how scared you were at the time, how your only car will be off the road due to no fault of your own, how it is lucky you were not injured, and the best one, how the council has failed to respond to your demands. Nothing like a bit of bad press for the council to MAKE them pay.
Cheers,
FRX026
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
