Ok a detailed report of everything that happened has been submitted to the council, and i have had confirmation that it was received. The guy in charge assures me it has been forwarded to the claims department and to get in contact with him in 3 weeks... I wont accept 3 weeks, ill be ringing him first thing monday morning. Apprently if it is established that it IS the councils fault i will have to get 2 quotes for repairs and then submit them and they will cover the costs...
Does anyone know what i will happen if they are unable to match the color? i have a custom pearl and if it dosnt look spot on I wont drop this...
Cheers.
Yeah, you have done the right thing.
This has happened to me twice, once a mower, once a pothole and both times I had my car repaired at no cost to me.
Write a report, get quotes, get photos etc.
Take the car to the council.
You should be okay.
I got my quotes for repairs,
Ranged between $1100-1400.
None of the dudes seemed too sure if they could match the paint shades either... The guy with the highest quote seemed most confident in getting it right though, but the council will just want to use the cheapest right?
do you guys know what happens when you hit something on the road (may have been a huge rock or a piece of tyre, unsure but heard the bang) and it buckles your rim and pushes out your tyre sidewall?! Luckily the wheel got pulled off that night, so it was noticed before it blew out on the freeway at 100k/hr.. :)
But still, unsure of all details except for the exact spot/road, do you think there's much chance of compensation to fix it? Can get photos of the damage but it'd be hard to prove exactly where and when it happened because it wasn't even a pothole and who is responsible for road rubbish/tyres etc?
Hi,
Councils are the worst to deal with, the are slow, so you will have to chase your money.
So just 2 suggestions
1 - Get a lawyer, bill the council for your legal costs as well as the cost of the repairs.
2 The magic words " trash TV", yep Today Tonight and current affair feed on stories just like this one. The angle to push is how scared you were at the time, how your only car will be off the road due to no fault of your own, how it is lucky you were not injured, and the best one, how the council has failed to respond to your demands. Nothing like a bit of bad press for the council to MAKE them pay.
Cheers,
FRX026
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
