Im thinkin about buyin one as well..
After a gd wash, if i go park the car in the garage, there wil be crap from top of the roof that falls down n pisses me off..
covers range from 20-80bucks from super cheap!!
The only down side is, you gotta take it off each time you want to get into the car or work on it/put it back on..
I guess to protect your car, you should buy one!!
or those portable carport things..
https://www.sau.com.au/forums/topic/111641-car-covers/#findComment-2059024
I think it's a good idea. At my house the garage is pretty much taken up by my dad's, mum's and bro's cars, so my car has no choice but to sit out in the front yard under the electricity wire where birds sit and shit on everything underneath it (should see some of the shit that comes out of these birds). Anyway, too save money and pain invest in one coz leaves and dust is not as bad a bird shit.
Prices do vary for em, but there are ones that have a special material that let the car breathe on hotter days etc so u dont get too much condensation inside the cover. I guess it's really dependant on how much u wanna spend.
:P:D
https://www.sau.com.au/forums/topic/111641-car-covers/#findComment-2059236
A major consideration when buying a car cover, is where you park the car.
If you park in a garage as siddr20 does, then it should be fine, provided that the car is perfectly clean every time the cover is put on.
If the car isn't clean, you're dragging dust and grit across the car while trying to fit the cover.
If your car lives out in the open, take pressure points into consideration...
Unless it's a custom made cover, it won't fit like a glove.
Generic car covers are floppy, and will flap around in the wind.
This flapping eventually wears at the paintwork.
Dust and bird poo are temporary mess which can be washed off.
....unlike the damage which can be caused by a poorly fitting car cover flapping on the paintwork for 16 hours a day.
Some of the high-end generic covers will have fluffy stuff inside them, this does bugger all apart from cause bits of leaves, small sticks and other debris which get blown up off the ground to get stuck in the fluffy stuff, which damages the paintwork faster with each "FLAP FLAP FLAP!"
Take a look at some of the portable car ports.
They may cost more than a car cover, but they cost less than a respray. :D
https://www.sau.com.au/forums/topic/111641-car-covers/#findComment-2059378
would any one be concerned about condensation being trapped between the cover and the paint work? after a while it may cause the car to rust or is just me being paranoid? that the second reason i dont use a car cover first being the whole scratched paint thing.
https://www.sau.com.au/forums/topic/111641-car-covers/#findComment-2060095
dad and i went halves in a car cover cause we share the garage so when mine is out side - i use the car cover - as its for a large car, you havre to use the straps underneath - otherwise big wind blows it off (which i found out..:D)
they keep the dew off the car and leaves and crap outta the way - very good if you dont have a garage
:D
https://www.sau.com.au/forums/topic/111641-car-covers/#findComment-2060211
:D
So you had no issues with the car cover at all?
https://www.sau.com.au/forums/topic/111641-car-covers/#findComment-2060215
none at all :D
i guess just make sure the car is clean before you cover it up.
dont go the cheap brands either - i had one of them for my old VT commodore and the elastic just lost its elastisty, didnt last long.
Think we paid 80 odd bucks at kmart/auto1 for this one and extremely happy with it :D
https://www.sau.com.au/forums/topic/111641-car-covers/#findComment-2060301
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
