Item: R34 GTT Custom Rear Tail Lights
Description/Info: Smoked Type with Circular/round patterns on both left
and right tail light set. The whole light glows dimed with the cirular/round patterns
glowing brighter. Indicator are in stock form (not smoked). Inner Light parts/assembly
only not including Red painted cover.
Price: New Price $250 (plus Nismo Eyelids for FREE if sold @$300) No Offers!.
Condition: Like New - No Damages - No Cracks - No Chips -No Scratches
Contact: PM me.
Other Info: Good For R34 rear conversions or to replace the stock R34 ones, ready to bolt on, just replace your painted cover over it. Taillights are a Genuine Nissan Item. Not Aftermarket items.
Reason For Selling: Changing them and maybe making another but diff Custom
Set.
Pics Below
Edited by FILO34
https://www.sau.com.au/forums/topic/111688-fs-r34-custom-tail-lights-pics/
  • 4 weeks later...
just out of curiosity
aren't these just standard tail lights, masked and sprayed with a tinting spray?
Yep thats right dude.
As I indicated that the items are stock nissan parts.
And have been masked & sprayed to a smoked/tinted type look
but not with a tinting spray though. It is a durable, weather
proof & heavy duty paint. Also which is why i call it custom.
Cheers.
  • 2 years later...
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
