A lot of people mention the extra weight of the R34 and R33 over the R32.
How much real world difference does extra kilos make to the performance of a car? Obviously less weight means more speed and better handling.
So considering the R33 GTS-T is 3.7% heavier than the R32 GTS-T, would this mean that the R32 is exactly 3.7% faster than an R33? (obviously comparing cars with exactly the same tyres, suspension etc etc).
If this is the case, then 3.7% isn't much difference IMO - I think driver skill would 'outweigh' this small percentage when it comes to any type of competition, be it track or drag events!
Here are the KERBweights I've found for each model:
R32 GTS-T - 1320kg
R33 GTS-T - 1370kg
R34 GT-T - 1410kg
R32 GTR - 1480kg
R33 GTR - 1530kg
R34 GTR - 1540kg
What do you think?
Edited by Primordial
https://www.sau.com.au/forums/topic/111689-skyline-weight-debate/
slightly different wheelbase.. way the power is delivered to the ground due to the chasis design, weight balance, different gearbox ratios, engine toruqe, even aerodynamics, etc.
It's silly to say "R33 weighs <this>" as well, as s1 and s2 are usually different, etc, etc.. I know series1 R32 (89/90) is about 40kg lighter than series 2 (91-92)
Ok.. ill rephrase my initial question.. I just didnt want this to end up another series vs series thread!
How much difference does X amount of weight make in the REAL WORLD. People talk about the R33 as a 'boat' etc. But how much actual performance difference/benefit is there as a result - NOT including other factors of course.
Im not talking specific numbers, just your opinion of whether a small amount of weight makes a difference in the performance of a car
R32 GTS-T - 1320kg
R33 GTS-T - 1370kg
R34 GT-T - 1410kg
R32 GTR - 1480kg
R33 GTR - 1530kg
R34 GTR - 1540kg
What do you think?
1989/90 R32GTST's weigh 1265 kgs, no sunroof, no ABS
For the same reasons 1989/90 R32GTR's weigh less than 1991/93 R32GTR's
Using engine power to weight is simplistic, you need to take into account the relative transmission losses.
Weight affects more than acceleration, there is also braking and cornering to be considered if you are looking at circuit work. There is also the effect of where the extra weight is. The extra ~200 kgs carried by a GTR is mostly on the front wheels, that has a big effect on how they handle.
Take a look at the success ballast applied to certain forms of racing, 40 kgs will take you from the front to the back of the grid.
:D cheers :D
Edited by Sydneykid
My 1989 r32 gtst 4door auto,with sunroof and a full tank of gas in full street trim weighed 1390kg, so im guessing it would weigh about 1320-1330kg dry, anyone else weighed there car??
yeah im with primordial, y do they say that 33 is too heavy wen in fact a stronger engine helps out balance the weight. why call 33 a boat? wen the 34 is heavier?
I think people say that because of the way they look, rather than how they go.
You've also gotta remember it's not all about the total weight it's about where it is. For example if anyone here has driven an old porsche 911 you will know what it's like with that huge amount of weight sitting behind the rear axle. It's like a pendulum and when the rear steps out it's very hard to catch. It also makes the front end very flighty and not seem as grounded. Compare that to a porsche boxer with agrubly the best place for an engine (midship) and you'll understand.
So if a car weighs more also think about where it carry's it's weight.
    • Welcome. Dont let anyone dissuade you from your dreams. If you want a gtr, keep sabing and you will eventually get one. I feel like if I had have bought stocks, those companies would have gone bust and I would have lost my money.  There's a gamble in everything we buy. I've had good times and bad. But... I've also met my absolute best friend through this network and can't imagine life without them(more like a brother). Keep in mind, some specific mods will change as technology gets better. If you feel like general chat, there's always the wasteland.....
    • Those are some very cutesy barriers! Is that common?
    • Saw this abandoned Honda Fit in a carpark that was getting repaved... they just 'cut around it' and continued with the job! There's a number of reasons why the car could have been abandoned, but as for the construction company, legally they don't have permission to move the car from the owner (who has moved on and can't be contacted) so all they can do it just leave it there with enough space around it so it won't get damaged.
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
