Won't fit.
I tried aftermarket wheels for an R32 GTR on Purple and they just touched so needed a few mm of spacer to clear, just to run the race rubber at DECA.
BTW the Brembos are the calipers and the discs come from a supplier in Japan (not Brembo) direct to Nissan who also provided the discs for the R34 Z tune.
If you have no ABS just be cautious of pinching the rears and locking them now the bias will be a little toward the rear. Of course if you did front and rear then you should be fine except with a particularly long pedal for the same braking force. The reason is a larger volume in the Brembo's pistons which means you have to push the brake pedal further for the same braking force so the rears can work as intended so will lock before the fronts. The consequences can be pretty severe loss of control.
I expect so although i must admit the GTR has more pedal travel than the GTST, although that has had a lot more attention to the brakes as it's my track car (when it goes).
Still, it remains that even if they were the same, the volume difference means not doing both axles leaves the car prone to rear lockup which is scary.
farking lazy bastards...
quote the bloodnut also known as roy:
R32 GTST
Master Cylinder diam (mm) - 25.4
Front Caliper Piston(diam x qty) - 40.4 ×4
Front rotors (diam x thk) - 280×30
Rear Caliper Piston(diam x qty) - 38.18×2
Rear Rotors (diam x thk) - 297×18
R33 GTST
Master Cylinder diam (mm) - 23.8
Front rotors (diam x thk) - 296×30
Now the interesting bit...
R32 GTR (Non V-Spec,)
Front rotors (diam x thk) - 296×32
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9
Front Caliper Piston(diam x qty) - (44+38)×2 ... leading pistons smaller then trailing
Front rotors (diam x thk) - 324×30
Rear Caliper Piston(diam x qty) - 40×2
Rear Rotors (diam x thk) - 300×22
So there isnt much difference between the Brembos and the std Nissan R32/33 GTST calipers and R32 GTR calipers.
I have the 34GTt rims on the auto 33 and they barely clear the Sumitomos so I doubt they will go over Brembos.
5052mm^2 vs 5309mm^2 is a big enough difference especially when the master size difference is so large.....
enough research. Ask Funky for part numbers.
