Won't fit.
I tried aftermarket wheels for an R32 GTR on Purple and they just touched so needed a few mm of spacer to clear, just to run the race rubber at DECA.
BTW the Brembos are the calipers and the discs come from a supplier in Japan (not Brembo) direct to Nissan who also provided the discs for the R34 Z tune.
If you have no ABS just be cautious of pinching the rears and locking them now the bias will be a little toward the rear. Of course if you did front and rear then you should be fine except with a particularly long pedal for the same braking force. The reason is a larger volume in the Brembo's pistons which means you have to push the brake pedal further for the same braking force so the rears can work as intended so will lock before the fronts. The consequences can be pretty severe loss of control.
I expect so although i must admit the GTR has more pedal travel than the GTST, although that has had a lot more attention to the brakes as it's my track car (when it goes).
Still, it remains that even if they were the same, the volume difference means not doing both axles leaves the car prone to rear lockup which is scary.
farking lazy bastards...
quote the bloodnut also known as roy:
R32 GTST
Master Cylinder diam (mm) - 25.4
Front Caliper Piston(diam x qty) - 40.4 ×4
Front rotors (diam x thk) - 280×30
Rear Caliper Piston(diam x qty) - 38.18×2
Rear Rotors (diam x thk) - 297×18
R33 GTST
Master Cylinder diam (mm) - 23.8
Front rotors (diam x thk) - 296×30
Now the interesting bit...
R32 GTR (Non V-Spec,)
Front rotors (diam x thk) - 296×32
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9
Front Caliper Piston(diam x qty) - (44+38)×2 ... leading pistons smaller then trailing
Front rotors (diam x thk) - 324×30
Rear Caliper Piston(diam x qty) - 40×2
Rear Rotors (diam x thk) - 300×22
So there isnt much difference between the Brembos and the std Nissan R32/33 GTST calipers and R32 GTR calipers.
I have the 34GTt rims on the auto 33 and they barely clear the Sumitomos so I doubt they will go over Brembos.
5052mm^2 vs 5309mm^2 is a big enough difference especially when the master size difference is so large.....
enough research. Ask Funky for part numbers.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
