hig guys,
need your help once mor,
ive just gotten my apexi s-afc 2 put in and i got 177 rwkw witht the following mods:
3" exhaust from the turbo
fmic (600 by 300 by 76mm)
turbosmart dual stage boost controller
all this with the stock turbo...
im running 0.65 bar of boost on high, just under 13 psi i think, i thought i could get more boost out of the stock turbo but the guy that dun the dyno said dont push it, so we left it at 13 psi.
anyway, car runs pretty good.
my mate wants to sell me his fuel pump out of his gtr for $200. worth getting??? i mean, i reckon $200 for the pump is pretty cheap, considering the bosch 044 is $400, and if i cant use the pump now i can always put it in later, after i get a bigger turbo.
but my question is if i do put the pump in will i notice any difference in power?? it'll probably drink more but that doesnt bother me as long as theres some sorta power increase.
looking forward to ur replies, thanx
https://www.sau.com.au/forums/topic/11174-do-i-need-an-r33-gtr-fuel-pump/
You probably won't notice an actual increase in power, as all you're doing is giving more pressure to the fuel system. Say you put larger injectors in, the current pump may have problems proving enough pressure for the new 'jectors to fire properly. Put in a better pump, the injectors can fire properly, everything's happy. That's what a new pump will do for you. Not a bad thing to do though. Better pumps are generally stronger and less prone to shitting themselves. $200 doesn't sound too bad.
sorry 0.85 bar.
thanx for the replies, i know i'll do the injectors eventually, but getting a gtr fuel pump for now wouldnt hurt would it???
how much is this guy selling the bosch 044 pumps for???
I can buy a Bosch 044 for about $280 (wholesale cost). The GTR fuel pumps are a considerable improvement, but I'd go for a new one considering the price difference. On your current setup it is not necessay, but if you are considering a turbo upgrade in the future then it's worth buying.
See'ya:burnout:
No, a pump will pump the same amount of flow constantly, and although a GTR fuel pump does pump more, it is the injectors which use the fuel. So aslong as your fuel pressure doesn't increase then there will be no increase in fuel usage.
See'ya:burnout:
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
