Ok well after 3 weeks of looking and nearly buying the wrong car from the wrong car dealer I have finally went down to see the guys at SSV in Melb and they matched me up with the new love of my life lol :(
I have always been a Holden Commodore guy and lately into XR6Ts but this car just blew me away I reckon this 96 model Skyline is a much better put together car than some of the new local cars.
Shes a 96 GTS-T Silver.
Auto.
Low Ks.
Blitz Dual stage turbo timer.
Cruise control
MTEC "HID like" 4.7K head light bulbs
Mongoose alarm and 3 point immoboliser.
Tinted windows.
Pioneer deck
GTR hi flow cat (i think anyway)
Pirellis
Otherwise stock...
Clean car and engine bay... didnt take engine bay pics as I just remembered them while typing this post up lol
Anyway enjoy pics guys:
Edited by Sir-D
https://www.sau.com.au/forums/topic/111741-my-new-car/
Auto's are very fun, but chances are your licence wont stay in your wallet for long.
but awsome ride dude, and nice to see you kept your options open to all car companys.
good luck!
yeah very fun :sweat: im smiling every time i drive it!
u mean autos make it harder to stick to the speed limit rather than manuals? i like to squirt it every now and then but i respect the car too much to floor it around every bend. i also had my lisense for over 7 years now... so bit more mature than ur average skyline owner.
https://www.sau.com.au/forums/topic/111741-my-new-car/#findComment-2062016
yeah very fun :teehee: im smiling every time i drive it!
Thtas good to hear. A lot of liners are just inexperienced drivers. I don't respect drivers that drive like they got something to prove. That kind of behaviour belongs on the track!
https://www.sau.com.au/forums/topic/111741-my-new-car/#findComment-2062633
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
