Hi
Have a highly modified R32 GTR that iam thinking of selling want to see if there is any interest for at the price iam wanting to get, car located in sydney.
Imported by me so iam the first owner fully registered with 12 months rego as just got it re-done has only done 8000km since being in australia. Here is list of modifications. Always serviced regulary with Motul oil always replacing fuel filter with every change. Gear box and Rear Dif Oil just done with Lightweight Shock Proof and Motul FFF LSD.
Dynoed at 20psi 360rwkw, 300rwkw at 1 bar tuned by JEM, these are safe tunes as its used as a daily driver.
96,000K on clock
2.6 litre twin turbo coupe with anR33 GTR engine and Trust 618z turbos
ENGINE AND ELECTRONICS
APEXi Power FC and FC Commander unit
HKS EBC
Forged Pistons
TOMEI 260 degree cams
TRUST adjustable cam gears
HKS 1.2mm head gasket
HKS metal gaskets for plenum and exhaust manifolds
Sard 680cc injectors
SARD fuel regulator
N1 water pump
HKS delivery pipe
Bosch intank 044 pump
Polished Plenum
Oil catch like the powerplay ones + oil Air separator
Cusco Intercooler Intake pipes with Custom Turbo Intake Pipes (aluminuim)
Custom Carbon Fibre Air Box with CAI
Cusco master cylinder brake stopper
Z32 airflow meters, new apexi pod filters
Dual core radiator with cusco air panel diverter
TRUST dual core Intercooler 75mm
TRUST oil cooler and oil filter relocator Power Enterprise magnetic oil filter used
OS Giken twin plate clutch with lighten flywheel
R33 Brembo brakes front/rear with Earls braided brake lines F/R
NISMO circuit link suspension parts
AS - front pillar brace bar, for more rigid chasis
Chasis has been Pop Riverted for extra rigidity from engine bay to front cabin
Adjustable Front Upper Arms (camber)
G4 - Height and dampner adjustable suspension
ARC adjustable castor rods
Rear HICAS cancellation bar
ARC front and rear strut tower braces
ARC front and rear sway bars
NO ABS
TRUST dump/front pipes
3n1/4 inch Kakimoto stainless steel exhaust
Hi flowed Catco cat converter
Push Start Button with kill switch
Battery relocated to the boot
RWD toggle switch made by Dirt Garage
GReddy Electronic Boost gauge and HKS oil temp gauge
4WD controller by Raceworx installed (Duncan)
Turbo timer
Trust Gear Knob
3point immoboliser with auto window lifter, works with turbo timer
Rays Engineering 17x10inch rims, chrome outter and gold innner 2 piece rims 255x40
N1 front bar with front lip on bonnet (carbon fibre)
N1 head lights
N1 lip on the boot
N1 style side skirts
Kenwood MP3 player with Clarion 6inch splits, Clarion 6inch rear speakers
Looking for 30K mark
Edited by godzl1975
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/
anymore pictures of the body and interior? idea of wat sort of power its making?
will have more pics of body soon...will put em up as soon as get the skirts on etc....making around the 570 ps mark..not sure how it is converted back to kw..anyone?
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/#findComment-2072857
570ps!!??@ all wheels or @ rear wheels at what boost?? thats 570x 0.7355 = 419.235kw
Thats up there for 2530 turbos but has been done by Paul Deimar
G Luck with the sale
dont think 570 ps at the wheels....i will be getting it dynoed soon..so will post up then.
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/#findComment-2081936
  • 11 months later...
Hey Aaron,
Still very interested! I have the cash and want to buy it after the compression and leak down test as well as the NRMA inspection and mechanics report.
I will pay for all the reports and documents as well as the time you took to get car there and back so your not out of pocket or time.
Please answer your PM's so i know whether or not to stop looking at other GTR's. Looking for a car and want to buy pretty much immediatley.
If something else jumps out like your car i might consider buying it if i cant get a response.
Thanks and let me know
Jake
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/#findComment-2994244
sale is quite old but Aaron PM'd me a few weeks back within my WTB ad for his car.
Negotiated for a week or two and pretty much agreed to a price if mechanics report, NRMA inspection and compression test came up healthy.
Since i asked for these i havntheard from him. Which isx sad cause his car has everything i want in a GTR.
Hopefully he has a read of this and gets back to me and i am looking to buy a car very shortley.
Would love a GTR but if i cant find one that i love then i might buy a S15.
AARON HIT ME BACK or i have to look for a S15.
Anyone that has a GTR like Aarons please PM me as i am looking and i have cash in hand right now!
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/#findComment-3008509
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
