post-3004-1143978050.jpgpost-3004-1143978050.jpgpost-3004-1143978798.jpgHi All,
Wrecking R33 GTST with front damage.
Most parts from doors back available.
Tail lights $100 ea
climate control unit $100
sony x plode mp3/cd $200
Passenger door with trim $200
Seats front and rear (rear have been retrimmed with blue inserts)$350
aftermarket GTR rear bar $200
rear pods $150 pr
front rotors $100
struts with lowered springs $100 pr
oil catch can with hoses $40
centre console $50, slightly bent at front lid is trimmed in blue
18 inch rims with 235 fronts and 275 tyres on rear worn in middle..1 front worn on one side other good $900
diff centre and housing lsd $500
crossmember with power steering rack etc and hubs $200..will separate
rear parcel shelf in blue $50
interior plastic trims from $20
roof lining $100 with lights
speedo cluster $100 showing 130,000 approx
hicas steering unit $200
drivers side mirror $50
More to come..can email photos of parts requested. Let me know what ur after I may have it.
Car is in sutherland shire sydney.
Thanks.
Edited by sav
https://www.sau.com.au/forums/topic/111769-wrecking-r33-gtst/
  • Replies 64
Posted Images
