  • Replies 64
Posted Images
not sure where is it located? I know it has a turbo smart boost controller on it.
What type of turbo smart boost controller is it? Just a bleed type, or a electronic type boost controller? If it's just a bleed then it's likely you'll still have the factory boost solenoid, but otherwise you'll have an aftermarket one.
I'll try to find a pic, unless anyone else here has one?
Yes its only a bleed type..let me know where its located or what it looks like and i'll tell you..someone else Pm'd me with same question
