  • Replies 64
Posted Images
I'm interested in the front disc rotors. what's their current thickness? do you have the lines from the front callipers as well?
can pick up this sunday if suitable. please call my mobile to work out a deal.
Justin...
0418663628
Could u send pics of inside door trim drivers side, i only require the pocket and surround if u can seperate excellent if not ill buy the whole thing!
Also pics of catch can.
If u Still Have Both Is Pick-up Availble For Anzac Day?
[email protected]
Thanks
Hi, I’m after a Rear Left small plastic side skirt (glues to base of rear quarter panel).. would you have one by any chance? thank you
i have a pair not factory think they are GTR style $150.00
Justin...
0418663628
they are 28mm..sorry for delay have been away..lines gone..if still interested 0417295636.
thanks
[email protected]
Thanks
sorry dont have drivers trim..catch can is behind pipe in the picture attached and pick up anzac day in morning fine with me.
do you have the plastic trim that goes around the manual gearbox and the ash tray?
i still have it although it has a crack in it and is painted blue..can be repaired and painted. Can have it for $20 including post if needed with ashtray as well.
