ive recently (today) installed a twinplate clutch, now it grabs beautifuly but is it normal that there isnt much room to play with to find the friction point and take of slowly?
also is there away i can re-adjust the pedal, at the moment its grabbing right at the top, its been like that with all the clutches ive had in the box. it hasnt botherd me, but now with the twin plate and not much room to play, its kinda hard to pull up slowly when youre already at the top. if you get what i mean lol..
any input would be good, thanks!
Yes its normal for the take up to be very short . You can ajust the rod length inside the car to vary the pick up point.
You can install a bigger slave ( Nismo have one ) so your clutch pedal will be lighter and the take up will feel better too but its never going to feel like a stock clutch.
Its easy to find and ajust . The shaft is attached to the pedal and you have to unlock ( undo) the 12 mm nut then turn the shaft clockwise ( as you are looking at it ) to shorten the shaft , that will bring the take up point lower to the floor . All you need is 2 spanners, a 12 mm open ender and maybe a 7 mm ( i cant remember this for sure ) .Dont forget a few turns will make a lot of difference.
I'm sure its been covered before do a search and you will find a pic somewhere, if you have any problems let me know and i'll take a pic for you .
If a workshop put the clutch in for you take it back to them and tell them to ajust the pedal for you .
  • 2 months later...
thanks heaps for this, wrxhoon. my twin plate clutch comes on real sudden so your post will really help me out. cheers.
Use a bigger slave, the slave will travel less when pushing the clutch pedal so it will feel like your take up is not as sudden and as a bonus you will have a lighter pedal but dont expect it to be like a stock clutch ..
while your comparing twin plates,
do you have clutch plates with springs or are they solid centre.
a twin plate with twin sprung plates is quite drivable
a twin plate with solid centre plates, is still drivable, but takes some, OK A LOT OF FINESSE!!
Solid centres are either in or out & hardly anything in between
oh ta wrxhoon, that's great. i'll check on it tomorrow.
yes mumbo i'm talking about the friction point - but the other thing is that there's no gradient of pressure, so at one point there's nothing and the next centimetre it's on full. i also have no experience using it! :)
my solid centre twin plate from direct clutch is bloody good to drive and take offs from low low rpm are really smooth and it never feels jerky at all. i can even ride it like a stock clutch on hill starts etc without any trouble.
though it rattles like crazy and is hard as a rock to press, but u get the good with the bad i suppose ;)
though it rattles like crazy and is hard as a rock to press, but u get the good with the bad i suppose :O
Cool, maybe mines still bedding in, wasn't in long before i blew up my gearbox, one too many hard hitting shifts, so looks like there's hope for me yet :D
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
