Sounds like the identical issue I have.. mines probably the input shaft bearing..
Mine is currently whining quite loudly in all gears and i'm getting the gearbox pulled down this tues..
If it's just a slight bearing sound - don't worry about it at the moment - when it starts whining than look at getting it replaced..
costs about $700 to replace it ($70 part.. rest labour) unless you can do it yourself.. also worth doing your clutch at the same time..
Will it cause damage if the problem isn't fixed if its a clutch throw out bearing?
No. Usually the noise gets worse with age as the bearing grease dries out and loses effectiveness. In one extreme case I saw, the bearing had seized, but the car had a LOT of k's on it and was pretty much junkyard material by that stage anyway (not a Nissan, btw).
In 99.9% of cases the clutch will need replacing before any problems will occur from a noisy thow-out bearing - apart from the noise, that is.
That said, and like every other 'I've got a funny noise' type thread ever started, each of us that has responded here has not actually heard the noise for ourselves, so to that extent we are 'guessing'. If you still have concerns you should get someone with appropriate experience to have a listen and follow their advice. Of course ours is free, theirs probably won't be.....
Edited by SteveL
If it makes the noise in neutral and gears with clutch released as you said.
It may be just the gearbox bearings in the best case scenario, or worse case it will be the hard casing worn off the input shaft and cluster gear set, causing the noise and wine.
Make sure someone that knows what they are talking looks at it, as you don't want to pay $600 odd bucks to get the bearings replaced if the hard casing is worn and its still going to make the noise after the rebuild anyway...
If you can pick up a genuine low km box from wrecker or half cut for $500, might as well just do that.
There is always confusion as to what is gearbox noise and clutch thrust bearing noise, if its the clutch thrust bearing it will only make noise when the clutched is pressed to the floor. This is when the carrier pushes the thrust bearing into the pressure plates fingers, causing the two halves of thr thrust bearing to spin and if the bearing is f**ked make noise obviously. (Only get this problem usually if the bearing wears out from the owner sitting at the lights holding the clutch in, instead of selecting neutral and releasing the clutch)
Just stating both issues as your post isn't entirely clear.
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
