I have a 3.5" from the turbo back , I was also wondering about that second muffler in there as my exhaust is quiet as a mouse (not necessarily a bad thing), maybe a touch too quiet .
That damn cat they put in when it was complied looks to be about 2.5" looks shonky . Am now considering a cat to suit the rest of the system and possibly taking that second muffler out .
https://www.sau.com.au/forums/topic/11191-exhaust-bends/#findComment-189228
to answer your original qusetion in a cat back exhaust there will be one 30deg bend then two other bends, these will depend on how the muffler is set up. I usually use a 45 deg and then a 30deg, this makes the muffler on a slight angle.
The rear muffler will determine how loud your car is and if you need a 2nd muffler or not. If you fit a decent muffler(ie not autobarn special) you can usually get away with just the rear muffler and your car will be loud but still quite at cruse and berable on WOT.
Stainless exhusts seem to resonate more in the cab than a mild steel system.
https://www.sau.com.au/forums/topic/11191-exhaust-bends/#findComment-189335
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
