this is my second post about this problem with my car i have had no luck in finding the problem or having some one to find the problem..........its really annoying
if the car is under a little bit of load in a lower gear and i put my foot down and let the boost build up it will hit max boost then go into loop home mode y??
i have had the car at nissan for a diagnostic.........nothing all levels are normal when the car is running good and in loop home mode
i have checked all the cooler pipes all tight
this was happening b4 i had my car modified.........now that it is modded its still doing it even after being tuned on a dyno
any one have any experience with finding what it could be ???
its now booked in at maztech for them to give it a go over.........
i feel like this problem has beaten me
https://www.sau.com.au/forums/topic/111945-limp-home-mode-on-32-gtr/
That's usually a crook AFM (switches to limp-home around 2500 rpm). Unless of course you can actually get it to go past the problem.
Alternately, it's a SERIOUS detonation problem, with the ECU doing some serious spark retardation.
had it run on the dyno at maztech......couldnt find any problems with it in limp home mode it made 162kw at all 4 wheels.......boost droped down to 7-8psi
they think it could be the fact that i had the stock boost restrictor taken out of the line and the boost solenoid cant handle the boost........all mixtures are fine...........so WTF..........i swaped itwith another gtr and same thing happens
could it be i need to use a boost controller ???
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
