  • Replies 126
The day is FULL, though there are several people on a waiting list.
If for some reason you need to pull out, please contact Tony at motorsport@wrx.com.au ASAP so your spot can be filled by someone else.
Please see the entry list on the WRX forums - HERE
IMPORTANT NOTE TO ALL COMPETITORS
Copied from the WRX Forums -
Due to the overwhelming number of entries for our Anzac Day event, we will have a reserve list of entries in order of acceptance.
Basicaly, these will be the entrants who will slip into the event should someone pull out, or not show up in the morning. This list will be up later today on the acceptances thread.
As a result of our numbers it is imperative that everyone gets to Driver's briefing on time as YOUR spot may be forfeited if you are not present and have not signed in before the roll call.
It would also be appreciated if everyone can ensure that their car is ready to scrutineer and make sure ALL documentation including membership cards and licence are in order.
Any hold ups may affect track time, and we want to get on track as soon as possible to provide maximum track time.
Please affix your competition number securely with race tape not packing tape preferreably as this sticks to the number
A reminder also that the 75db limit is usually strictly enforced at Sandown due to local residants We have no control over this aspect of the day.
Finally, have your membership card ready at the entrance gate as you may be asked for some identification before entering the complex.
Tony Dalleaste
Motorsport Director
Impreza WRX Club
If they are glass you should. Though sometimes the scrutineers miss it. If its rainy and dark then you will be using them and a good idea to tape them up. Some Cheap clear contact will do the job, just be sure to get it off as soon as you are done as the heat fromt eh light can kinda bake it on and a 30 second job of removing it turns into a 10 minute job requiring acetone
great day
Well a big thanks to the one and only BRISBY! for making mine and my dads day great, and to say it has put the biggest smile on my dads face no one could remove. (Brisby helped my dad in driver training) Thanks again man
Scott and John
A birdie tells me a certain Lada driving official would sure like a drive of an R34 capable of punching out 1:20s :(
I had a ball today. Great fun going round with John...and thank god after the quick cooler pipe fix, the R33 was free of my curse :)
...but yeh,,, good to see everyone still smiling despite the few problems seen on the day...and ditto, the officials once again donating their time.
That said, i am so keen for the next Sandown...massively keen to see if i can improve on my last attempt
Good work everyone. Great day, great times, no incidents :(
BTW: I think I need a faster car - SuperLada didn't even top 90kmh up the back straight.
Good to see other clubs involved, but I must say I have removed the word 'clubman' from my Christmas card list. Mostly nice people - but two things during the day did not particularly impress me, nor win my favours. That is all I'll say.
Also - that Rarri is so porn. I LOVE it.
Thankyou to whoever broke their cars this morning and got jarrod and myself out there! (hope all is well) was an awesome day, sandown is such an awesome track, even if ya rotors are corrigated... Thanks to the officials, flaggies and timers etc, was well run. (I think they need to introduce an oil/fluid flag so people know to stop ASAP). anyway, ill be posting up some pics tommorow.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
