i have a ticking noise coming from something in the engine bay.
sounds like its coming from the passenger side of the car towards the front of the engine.
its louder on start up but gets a bit softer after a 10 seconds of running but i can still hear it.
any idea's before i take it to someone to get looked at end up paying for things i dont need?
thanks
ash
https://www.sau.com.au/forums/topic/112010-i-have-a-ticking-noise-help-please/
Cold or Warm starts?
Could be the lifters just getting their first sqiurt of oil for the day.
Alternativly, the stock injectors are pretty damn loud on RB's?
Could also even be the fan hitting against a pipe (in my case FMIC) or wire thats loose?
Has your timing belt been changed; or alternaviely how many (genuine) kms has the car done?
btw:- bring it out on the next sthn SA crusie!
Edited by Tangles
i had a similar noise with my series2 not long after a long trip recently so got the belts all done on the front including the timing belt just to be sure and noises all gone now, all the drive belts were cracked an mechanic said it sometimes happens cos of the chemicals they spray the cars with when they de-bug them for quarantine?.
must react with the rubber i spose.
timing belt was done very recently
its on both warm and cold starts
fan clears the cooler pipe... just :D
i took it to my local mechanic today and he thinks its the exhaust manifold gasket. sound right to you guys?
"Just"
Theres your issue
Paint some black paint on your pipe, then start it and see if it rubs any of the black paint off.
I know because my pipes are painted black and the paint gets taken off. Put some sandpaper there to wear it down.
no it isnt that.
it clears. that was the first thing i thought it was.
there is a 5 mm gap
ive grabbed the pipe and pulled it up away from the fan and its still there. ive also pushed the pipe down and it still doesnt quite touch the fan, its braced quite solid.
I'll be doing the same when i get my turbo high flowed, i had a nut missing off my exhaust manifold, Doesn't seem to be leaking but will pull it all off and replace the gasket just to be sure.
  • 3 weeks later...
I head a similiar noise that begun just after I had my cat off and on. I hunted it down to 3 nuts and studs missing from my exhaust manifold! I dunno where they went, car is an unmodified import. I guess the stress on manifold of me playing around with cat made it start to leak.
Why are other peoples exahust manifolds missing bolts too? Seems odd to me. Suppose I'll have to pull it to bits now!
what oxford1327 said interests me, ie the chemicals sprayed on to decontaminate the car. As mentioned in "electronic rust prevention" the undersides of my S1 ar veiled in a film of rust (corrosion). Especially the bits that were cad plated.Apart from having a flat battery yesterday this rust is the only thing that isses me off.
Its going to cost $640 at Endrust to get it fixed.
Odd - mine is completely rust free underneath - pefect! Nor have I found any ceramic bits as yet... as yet!
I've got the same noise in my series 1. Stock injectors are noisey. Seems to be a nissan thing, the ones in my sr20 wern't much quieter. But i have also noticed that the boost control solernoid is also a bit noisey.
There are pollution control solenoids which ticker away - best solution is to rubber mount them. However these are at the back of the motor and not the front, so I could be sending you on a rabbit hunt.
  • 1 month later...
Though not a Stagea Tick, but still Nissan.
Gave the S13 an oil change and this time changed the filter and changed the plugs. Put in the required amount
of oiland on start up a diabolical tick. More like an elf with a sledge hammer. The boys thought some foreign body got in thru a plug hhole, etc etc etc. Every time it started, tick,tick wtf.
The oil light didn't come on an the ECU was checked. Nope.
In desperation I put a bottle of Nulon in. The effin tick Stopped. Why.
My thought is that somehow the oil pump got an air lock and maybe the extra bit of lubricant helped it pick up properly. I have never experianced any5thing like this in 50yrs of oil changing, and we have changed the S13 and 180sx drifters many times before with no probs.
After the noise went away, the car was taken for a thrash up toBrissie and the next day was flogged a bit at
Queensland Raceway.Runs sweet as a nut.
Has anybody experienced this type of problem? The guys on Sil had no ideas.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
