G'day people! Im looking at gettgin my car sprayed but am after something different and was just wondering if anybodys got pics of a skyline (preferrably r33, but i spose it dont matter) with speed stripes? And by speed stripes i mean two stripes running down the length of the car?
Anything id appreciate
Cheers
Musky :D
www.gaypaintjobs.com
*************edit by Pva_Glue*****************
Darky! come on mate you better than that! lucky I have sense of humor in me!
I see your Warn is 0% if you keep this up it may go up :D
cheers
Mod
lol dark!
Hey each to their own. There's no need to be rude.
Maybe try www.stripesonskylineslooksofinggay.com
spend the extra money on a quality paint job :( You'll be better off. That said, here's a car with gold pearl stripes painted on it.
Last time i come to this site for advice...to each their own ay, i dont give a shit what everyone else thinks.
How about i be like every other skyline and have my car black or white, or maybe add some pearl in there....
sorry mate, "Darky" say things without thinking 1st.
I hope this doesnt put you off coming back to out photgraphy section, for that I deeply sorry.
yes there are many sites, if you check out member's ride page there will be many skylines with art work on the car.
cheers
Glue
ps. Darky you hurt his feelings! STOP IT! :(
cheers
Glue
There's already too many skylines driving around thinking they're Dodge Vipers
well where i am from there are pretty much only black or white skylines and mine is white, sick of being part of the crowd. I have never seen a line with stripes.
I asked the question just so i could see photos to see what it looks like, i didnt ask for peoples opinions.
EDIT: 'PVA Glue' thank you for pointing me in the right direction.
Edited by Musky
sorry guys, i had a really bad day :laugh: and i suppose what was said rubbed my in the wrong way, still shouldn't have reacted the way i did. I do apologise and thanks for the advice and pics :D
Musky
  • 3 weeks later...
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
