garage cleanout time
r33 s1 rear pod--drivers side 50$ -SOLD
r33 s1 cam gear/timing belt cover 50$
r33 s1 plenum + crossover + turbo pipes 100$ -SOLD
r33 s1 standard computer 200$
r33 s1 dash 80$
r33 s1 radiator + shroud 100$----sold
r33 s1 coil cover 20$
s1 rb25det cams 200$ --SOLD
r33 s1 floor mats front and back middle mat 80$ -----SOLD
r33 s1 bonnet wine red 200$
r33 s1 wing 100$
r33 s1 drivers side mirror 80$
r33 s1 washer bottle 30$
r33 s2 air box 50$---SOLD
r33 s1 right indicator 20$
r33 s2 steering column 2 pak silver 60$
r33 s1 exh cam gear 50$
r33 s1 right back seat interior panel 50$---cloth trim removed
r33 s1 left side back floor matt 10$ cant find other one yet...
r33 s1 standard side winkers 30$
r33 s1 clock demister hazzard sidemirror controls 50$
ignore circles in bonnet pic...shitty flash on cam..
Edited by thizzle
https://www.sau.com.au/forums/topic/112054-r33-gts-s1-s2-garage-cleanout/
What colour is the drivers mirror? is it convex or straight glass?
the mirror is gold/green but its been scraped off a bit as u can see the wine red under it...
i couldnt handle havin no mirror while it got repainted so i bought one from sss auto..its glass.
Edited by thizzle
80$ cuz i cleaned all that film that peels on s1 off it so now its perfect for paint
all vents included plus buttons + clock are round some were 2..
60 just for the dash if u pay shipping
Edited by thizzle
    • Swapped the injectors around and the misfire followed. I went ahead and ordered the Deatschwerks 550cc injectors and am currently waiting for them to be ship and arrive. In the meantime, I've had my Nistune soldered to the ECU. Tested it, and and tried it out with the software. Everything should be prepared for when the injectors arrive.
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
