hey fellas my names luos, i was just wondering if any yall got the spare time can you please chop my car for me like slam some deep dish rims on it sort of like the ones on the gtr in the pic and paint it like a wine red sort of a colour,with like a vertex type kit so i get a fair idea of i can do to it
chur bro
much appreciated
Edited by driftmunkee
https://www.sau.com.au/forums/topic/112056-chop/
OK, it all starts with a good picture of the car, the third one there is not too bad, but you need to have not shadows or massive light changes (both apparent in pic 4) for a good colour change.
Take picture in the middle of an overcast day. Or search for wine red R32 pictures on google or something :thumbsup:
cheers
https://www.sau.com.au/forums/topic/112056-chop/#findComment-2066055
  • 3 weeks later...
  • 3 months later...
nah man no pics of it out or being pulled out of the hole.
i had it pulled out with a franna crane some guys from downer engineeing
helped me out. i was actually heading the oppisite way to what the car is
facing in the picture. heres a couple of pics from when it was at the panelbeaters
after the first coat of paint.
https://www.sau.com.au/forums/topic/112056-chop/#findComment-2403222
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
