R32 GTR Skyline 1989 Model
Standard options include:
-Air Conditioning
-Alloy Wheels
-Climate Control
-Power Steering
-Central Locking
-Power Windows
-Tilt Steering Wheel
-Rear Spoiler
-Anti-Lock Brakes
-Bucket Seats (front and rear)
Aftermarket Parts Include:
-Apexi Twin Pod Filters
-Greddy Solid Aluminum Radiator Pipe
-Greddy Radiator Ducting Plate
-Excedy Heavy Duty Clutch
-Autometer Phantom Boost Gauge
-Full exhaust from dump pipes back
-Aftermarket Diff
-Heavy Duty Timing Belt
-JVC Headunit KD-SH99R
-Kenwood Rear Speakers
-Custom Number Plates: ZIL32A
-4WD/2WD Switch Setup (can be switched without stopping)
-Re-Conditioned Turbo's
-QuikTrac Sattelite Tracking Alarm
-Polished Cam & Rocker Covers from: NBP
- Rego til January 2007...
- 113,000 KM on the Clock
-NOTE: The dash is perfect only tiny bits of lifting on the dash, no massive eggs like most of the other R32's I have seen, and also no broken aircon vents etc, all perfect!
- Can also include 2xSignat 15" Subs and 1xSignat Monoblock Amp for an extra $1,000...
Pictures:
New Pictures:
My newly finished polishing from: Northern Beaches Performance...
Reason for sale:
Have found a new project car and need the funds to get it started! :(
Price:
$19,900 With QuikTrac Alarm and Head Unit
$19,500 Without the QuikTrac Alaram and Head Unit
Edited by DRFTD_32
https://www.sau.com.au/forums/topic/112105-fs-black-r32-gtr-19900-neat-look/
I've seen this car, been in this car and worked on this car... can honestly say it's very clean and an absolute bargain at this price!
Robbie best of luck with the sale, NBP will have those parts polished up in no time for ya!
I dont have any interior shots at the moment! The car is currently in the work shop getting some polishing etc done! When that is finished I will have some more pictures up!
Thanks,
Robbie
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
