R33 series 1 gtst with 3ltr Rb30 bottom end (instead of 2.5ltr) Motor done approx 15000km
Located near Gosford NSW
**has 12 months Rego***
Details
*RB30 block
*Arias Forged Pistons (20 tho oversize)
*Shotpeened rods
*ARP rod bolts
*New rod Little end bushes
*New ACL main and big end bearings
*Mild Head port and polish + full head service
*3 layer metal head gasket
*all new gaskets, seals, welsh plugs etc
*Custom oil catch can and breather
*Garrett GT35/40 dual roller bearing turbo
*Xforce high mount stainless exhaust manifold
*50mm external waste gate and screamer pipe
*3 inch exhaust turbo to cat with 3 inch cat. 3.25in cat back with stainless Jasma rear muffler.
*Custom inlet Plenum and EF falcon throtle body
*Hybrid bar and plate intercooler
*Turbo smart type3 blow off valve
*NOS brand nitrous fogger kit and bottle
*600cc injectors
*Bosch 044 external fuel pump
*Custom 1.5ltr surge tank
*Walbro high flow intank pump
*malpassi fuel pressure reg
*Wolf3d engine management
*Apexi electronic boost controller
*PLX Wide Band air/fuel ratio meter with gsensor and laptop data logging
*Xtreme extra heavy duty 5 puck ceramic button clutch (1200kg pressure plate)
*19 inch zenetti kaotic rims 19x9.5 (265/30/19) rear and 19x8.5 (235/35/19) front
*KYB lowered springs and shocks
*White line rear camber kits
*GREDDY electronic boost gauge with recall and warning light
*GREDDY electronic oil temp gauge
*GREDDY turbo timer
*TRUST short shifter kit and knob
*Pioneer cd/mp3 player
*Pioneer front splits and custom door pods
*Pioneer rear 6 inch speakers and custom parcel shelf
*Sony explode 12 inch sub and box (sub damaged but still works fine)
*Boss 4x75wrms amp
Car has produced 301kw (403hp) at the rear wheels on 18psi, will make more with more boost. Set of cams and larger exhaust housing will see 350+ Has done a 12.1@ 118mph on a 39degree day with lower boost and no NOS. Should Do high to mid 11 on cooler night without nos and mid to low 11 with NOS Email or ring with any question [email protected]
Asking $25,000 or best offer
0422802102 Ask for scott
Edited by OFENSV
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
