Hey all just wondering if anyone in adelaide has any intrest in buying my 95 R33 GTR V spec
If theres any intrest please pm me for details or call me on 0416 085 323.
mike
Some Details
1995 R33 GTR V spec 2
RARE Purplish colour
Tilbrook dyno 262 rwkw
Std internals & turbo’s @ 1 bar of boost
Estimated ¼ mile, high 11’s
Platinum 7A11’s NGK plugs
102,000 km on clock
98 GTR series 3 HID’s
Front & side clear indicators
265/35/18 all 4 corners (new tyres Nankang)
LMGT2 Nismo rims 18/9 ½ (400R rims genuine rays engineering).
3 ¾ sainless steel exhaust ( Japanese style)
after market secondry dumps
Tein HR’s height adjustable coil overs
Rear adjustable upper control arms (Silk Road brand)
Front adjustable upper control arm bushes
Front adjustable radius rods (ARC)
All suspension set to 1.5° negative camber with + 4 on front casters
3 months old fully rebuilt gearbox all new bearings & syncro’s
05 edition 6 months old Exedy twin plate clutch (pull type)
Apexi power FC series 2
Doesn’t knock over 50( any temp)
Apexi air filters & cold air intake
Custom aluminium cold air box
Greddy remote oil cooler & oil filter
Custom aluminium oil catch can (legal)
All standard strut braces & sway bars
Recent big service almost everything new in engine bay
Trust GTR front mount cooler
Carbon Fibre front bar insert( around cooler)
Std bov’s
Nismo Earthwire Kit
Tisonics turbo timer alarm ( worth $900)
Interior very neat series 2 dash surround
Billet style handbrake, button & gear knob
White leather handbrake/gear knob surround & seat inserts
Genuine GTR floor mats
Kenwood Mini Disk player (very cool)
Std clarion speakers (excellent cond )
STD GTR brembo’s
Endless rear brake pads ( EP291 S-SS)
Nissan ( Green) front pads
Brand new GTR starter motor
R33 GTR car bra ( will sell seperately )
The car is washed every week and waxed once a month it resides every night on carpet in a locked garage. It handles awesome set up for track use and hills driving not for the faint hearted.
Regretful sale, but must go ( need money for child custody fees )
Had the GTR for 3 years and has always been reliable.
$ 40,000 is starting price but wont budge much
its worth every cent its one of the best looking GTR’s in Adelaide
and will always turn heads.
More pics on there way soon
post-9995-1144725845.jpg post-9995-1145503670.jpgpost-9995-1145503734.jpgpost-9995-1145503780.jpgpost-9995-1145503822.jpgpost-9995-1145503860.jpg
Edited by trick
https://www.sau.com.au/forums/topic/112137-my-car-for-sale/
Sorry to hear that you're looking to sell you car.
Anyone looking at buying in this price range, this car is fantastic. You MUST have a look/go for a drive in it
Cheers Dan
Details up and some more detailed pics coming this week.
https://www.sau.com.au/forums/topic/112137-my-car-for-sale/#findComment-2086223
Quick question on your car. Where did you get the heat shield from for your pods? and where have you plumbed your catch can too?
Great car hope mine looks and goes this good. Good luck with the sale.
hey i made the heat shield for air pods and the catch can has inlet from engine entering the at the bottom of the can then the outlet from the can, thats just air, plums back to the std spot on inlet of the rear turbo at the back.
https://www.sau.com.au/forums/topic/112137-my-car-for-sale/#findComment-2107607
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
